O.D. Bolt on to Muncie. (Gear vendors type)
Transmission to Rear-end
Re: O.D. Bolt on to Muncie. (Gear vendors type)
Post by MadBill » Mon Oct 31, 2016 2:22 pm
Thanks Auto.
That's a concise and fantastic summary! I have a low-mileage '70 1/2 Z28/M21 that I bought new. In the late seventies I swapped in a 495" aluminum Can Am engine but parked it not long after. It's now going back together with a Jones solid roller and a number of other changes that should add up to ~750 HP/675 lb-ft.
I've experienced wearisomely overtaxed trannys before (e.g. 215" Buick-powered Beetle) and assumed I'd need an alternative box to enjoy my ride, (I scored a Crovetter ZF 6 speed, but then realized I'd have to take an ax to the floorpan to fit it.) but it sounds like your M23 should handle it just fine and would be a simple drop-in. Hmmm... maybe I could re-stamp it and retain the 'all but engine numbers-matching' status.. :)
autogear
Post by autogear » Tue Nov 01, 2016 9:27 am
An M23 (2.20/1.64/1.27/1.00) or one of the M23W's (2.56/1.75/1.36/1.00 or 2.56/1.90/1.36 or maybe even 2.56/1.61/1.26/1.00) would fit the bill nicely. Your shifter, driveshaft, slipyoke, bellhousing, etc can all be retained if you like.
You can get an M23-series gearbox from Medatronics (5speeds.com), Jody's Transmissions, us, Midwest Muncies; or I may have a smaller distributor local to you.
Here's a ratio chart (no pricing) : http://www.autogear.net/wp-content/uplo ... odular.pdf
You'll be in the $2200-2700 range depending on distributor, options and whatever extra accouterments you need.
Cheers!
Nathan
autogear
Post by autogear » Tue Nov 01, 2016 9:49 am
pdq67 wrote:"a C355 aluminum midplate"
I thought you installed a steel or cast-iron midplate?
We did. It was Nodular Iron and cast in several US locations over its life. However, as the M23-platform has increased in scope, we needed an updated design. The new design has the mainshaft bearing bore flipped over; to more adequately support the snapring groove. The dimensions were changed to eliminate the (2) high crush gaskets (even our gaskets are made in America from gasket material designed for Abrams tanks). Eliminating the gaskets means less chance of misalignment between the mainshaft and the rear bushing in the tailhousing (the bushing in our tailhousing is an OE bushing that is designed to be reamed-in-place, not a fits-all service replacement bushing). In order to go to the "gasket-less" junctions between the 3 main castings, they all SHOULD be of similar material. We originally looked at 357-series aluminum, but this has beryllium copper (BeCu) in the composition, which is bad juju for machinists. C355 is what Dart uses for their Pro-1 cylinder heads, and their aluminum engine blocks. It is approximately 20% stronger than the 356-series aluminum we use for our legendary SuperCase. Our C355 aluminum midplate is half the weight of the nodular iron; and cheaper to boot. Still cast and machined in the US of A.
Cheers!
Nate
Post by MadBill » Tue Nov 01, 2016 8:30 pm
That's very appealing! Thanks Nathan.
autogear
Post by autogear » Wed Nov 02, 2016 10:19 am
Bill;
Its my pleasure to contribute to a great place like SpeedTalk. If it helps - our Canadian distributor is Gears to Go in BC.
novadude
Post by novadude » Thu Nov 03, 2016 11:24 am
Autogear... can you explain more about the "gasketless junctions?" How are you sealing this thing?
EDIT: Looked at your site, and I really hate the idea of "N-series" components replacing the good backwards-compatible stuff. Guess this means resto guys will have to resort to offshore junk in the future? :(
autogear
Post by autogear » Thu Nov 03, 2016 1:47 pm
Edit: This ended up quite lengthy. Sorry.
novadude wrote:Autogear... can you explain more about the "gasketless junctions?" How are you sealing this thing?
You need a TIG welder and a steady hand...
Kidding. I should have said "no more paper gaskets between the tailhousing, midplate and case." Paper gaskets impart a lot of variation due to humidity changes. They require a certain amount of crush and create the ability for the parts to move slightly, independent of each other. We use Valco import grey RTV applied in a very fine bead with their "tube grip" pliers. You could use an anerobic sealant, which would make an even stronger joint, and a more rigid transmission.
I understand the desire to keep the OE-style (what we call the M-series) reverse geartrain, mainshaft and hubs. Please understand the N-series is being developed to carry our flagship product into the future. Similarly, no one expects every Jerico part to fit their 64 Falcon toploader.
* We will still carry the traditional Muncie hubs. Both the standard diameter, hardened hub and the slightly oversized hardened hub (that will only fit a OE Spec dimension slider - no cheap sliders here); made in Italy.
* We will still carry the traditional Muncie reverse geartrain; made in Italy.
* We will still carry the forged, plug quenched sliders; both the stock style 36-spline, and the "Torq-Lock" 36-spline. Made in Italy
*We will still carry the forged 18-spline, plug quenched lightweight sliders. This is a double broached 18-spline slider, that is then properly heat treated. It is NOT a hardened 36-spline stock slider that has been modified by grinding away the splines. Made in Italy.
****The ONLY thing that will be left behind is the AG Muncie-style lightweight mainshafts. These are gundrilled at the factory under the forward gears (the hole stops under the 1st gear journal) before they're hardened. Made in Italy. I have about 300 of each (27 and 32 spline) to be sold.
George has been working here since Muncies were cutting edge technology. Muncie mainshafts were almost never sold over the counter ("I don't really remember selling more than 25 a year back in the '70s" - George). They are very durable. In addition, very often the large reverse gear, and its mating gear are replaced as standard practice in Muncies. So if you HAD to replace a mainshaft, chances are the reverse geartrain was replaced at the same time. That leaves the only "extra" N-series parts being the sm. reverse idler and the hubs. You can re-use your sliders if they're still sound.
The majority of the mainshafts we sell today are for the construction of new gearboxes; in which case, you need the reverse geartrain and hubs.
Worst case scenario, you may need to source a Muncie mainshaft; or purchase an OE-style Italian one and stick it on the shelf. Everything else will remain produced in Italy and sold through our distributors, or factory direct.
Nathan
novadude
Post by novadude » Thu Nov 03, 2016 3:33 pm
Thanks for the clarification. From what I read, it was not entirely clear that everything but the mainshaft would still be available for the traditional Muncie, that you would still be carrying the "old style" hubs / sliders, and that all other "new" parts would fit old cases.
autogear
Post by autogear » Thu Nov 03, 2016 4:16 pm
No worries; thats what Im here for. We try to publish charts and descriptions that are easy - but at the end of the day, we are gear guys; and look at this stuff for weeks straight before its released...it always makes sense to US because we see what we want it to say.
Thanks for asking!
Nathan
Post by pdq67 » Thu Nov 03, 2016 6:35 pm
autogear wrote:Edit: This ended up quite lengthy. Sorry.
Nathan
Fwiw, Gast Air motors use, "cigarette pack", cellophane film as their end plate gaskets. I have over hauled several of them when I was gunning refractories because they were used on REED, "SOVA", and, "LOVA", gunite machines. Charlie and I trued up the plates very carefully using an 8" long Nickelson(Sp?) fine tooth triangle file and WD-40.
This is another of what I call, "a feelie", deal..
Now as for the Muncie 5-speed, I see that Tremac balloons out the tail housing to fit the 5th gear IF NOT MISTAKEN???
Do the same thing to a REAL Muncie and go!! Just keep it the same length as one is stock now and fit the cross member mount bolts like is done for a TH400. Hell, moving a cross member back to fit a REAL Muncie 5-speed would be a, "piece a cake"!!!
Can't fit bolts to install the new tail housing then use studs in the tail housing that tighten down from the front and not pointing to the rear of the new tail housing....
George, isn't it(?), I offer my BSME for FREE to be in on this!!
A 700+ torque handling 5-speed Muncie will be a game changer as I see it that will keep our old 1st/2nd/3rd Gen. Camaros alive!
novadude
Post by novadude » Fri Nov 04, 2016 10:48 am
I guess you don't need a reverse gear with your plan?
"Ballooned" tail housing wont fit in any early muscle car tunnel, and you can't Balloon anything too much as you need a place to bolt a shifter.
If it was easy or practical, George would have probably done it already, given all the other parts they've been developing for Muncies.
autogear
Post by autogear » Fri Nov 04, 2016 2:49 pm
"The 'dude knows..."
Truth is you're trying to cram 5LB of poo into a 3LB bag. The reverse geartrain in a Muncie is a space hog; and the tunnels for these cars are not conducive to bulgy transmissions (Ford had the 'pregnant' toploader case in trucks).
The TKO has mainshaft 5th formed ON the mainshaft; and they swung the shift system over the top. Talk to Mopar guys about fitting a TKO in a stock application. If you didnt use a slip yoke, it might 'help' in some aspects. You do know some corvette guys use a TKO converted to sideshift?
in a sci-fi world; my PERSONAL choice would be a 3.x:1 1st, direct drive 5spd with a 2.97-3.23 rear axle would be everything I needed. (3.2/2.56/1.75/1.36/1.00) for all around ass kicking. Dead nuts smooth and quiet in high gear; GT style 2nd-5th, and enough 1st gear to run a high 2's rear axle. Road Racing could go with a 3.2/2.20/1.64/1.27/1.00 Dedicated drag racing could be 3.2/2.56/1.90/1.36/1.00.
Im just being a gear nerd
Nathan
Post by pdq67 » Fri Nov 11, 2016 8:25 pm
autogear wrote:"The 'dude knows..."
Nathan
Nathan,
Please send me a set of Muncie drawings and I will figure out how to do it! And my damned computer won't open pdf's!
And this is, "FREE for FREE", just like my 1st Gen. front 13" rotor/2-15/16" dia. big, single piston calipers, "pdqCBB" brake template that I have sent to a bunch a guys in the past.
I will PM you my address.
autogear
Post by autogear » Mon Nov 14, 2016 1:05 pm
Paul.
I have passed it on to the powers that be as it is above my paygrade Sir. Thanks as always for your interest and continued support.
Post by pdq67 » Thu Nov 17, 2016 5:04 pm
Thanks Nathan.
Please tell me yes or no, or that Autogear would be glad to have me look over a set of Muncie plans to SEE if I can do what I would love to see be done!
A real, 5-speed OD, 700 Torque, Muncie. Make it all gear and not planetary geared like the Corvette 4+3!
If LGT can make one with an internal shift design, then a 5-speed Muncie should be a piece a cake, IMHO.
Change the rear tail housing any way that needs to be done, BUT hold the OA length of the complete trans. so it fits and if a little trans tunnel sheet metal needs to be worked over so be it.
And please, I'm not out to offend anybody here, but rather would really LOVE to see a real 5-speed Muncie created.
http://legendgt.com/wp-content/uploads/ ... etails.png
