Russian made diff's.
Transmission to Rear-end
dfarr67
Post by dfarr67 » Fri Sep 23, 2016 2:16 pm
http://gw4x4.ru/index.php?id_product=21 ... er=product
Anybody have experiance with these, I have two Truetracs in service, was thinking about putting this in the Toyota front IFS. Light 4x4ing, winter driving. Very reasonable $$, otherwise the diff stays oem.
Geoff2
Re: Russian made diff's.
Post by Geoff2 » Mon Sep 26, 2016 5:10 am
Couldn't be any worse than Russian made motor bikes..........which would often seize before the new owner made it home.
AC sports
Post by AC sports » Mon Oct 17, 2016 7:46 am
OK. I'll reply to this given I've been using them for 10 years now. I refer to Russian made torsen and clutch type lsd's manufactured by Val Racing. I too was a little skeptical so sent the torsen spur gears to get tested. The results were excellent according to the test lab. Can't remember the exact Rc hardness but we're very consistent. Machining is excellent as is finish. I've been running a couple on the track and one on dirt for over 5 seasons without maintenence. I recently pulled my road going torsen apart after 10 years street and hill climb use and gears were consistently bedding, no noticeable wear.
In fact here is another I installed over the weekend on a used gear set for a buddy on a budget. Remember I only have experience with Russian made lsds made by Val racing . Can't comment on others.
dfarr67
Post by dfarr67 » Fri Dec 23, 2016 10:40 am
Too bad I didn't see this awhile ago. I ended up going with a Spartan Locker- but we'll see how it drives. Doesn't look like they make a 7.5in Toyota.
englertracing
Post by englertracing » Sun Dec 25, 2016 4:55 am
I hear they like a couple of glugs of vodka per liter of diff oil.
