rear end question
Transmission to Rear-end
jackdaniels
rear end question
Post by jackdaniels » Tue Oct 03, 2006 5:03 pm
Hello everyone,
need your help one more time :oops:
My friend has a '79 pontiac firebird, and he wants to take it to the track..
Ok the info on the car is
400cid pontiac engine / 400 hps approx
his cam: 214 / 224
vehicle weight arond and very close to 3500lbs
torque converter 3200 stall
with a rear end of 3.73 posi / 8.5 10 bolt
he wants to try slicks 26 x 10 /r 15
he is quite concerned if his rear end will ressist at the track....
do you guys have any advise on this?
or does he has to stop worring???? :D
thanks again
Daniel
Ed-vancedEngines
Post by Ed-vancedEngines » Tue Oct 03, 2006 5:22 pm
His rear end should be ok, if it was assembled and set up right.
I do question your weight numbers though. That car is pretty heavy unless it has been on a diet.
The cam duraton looks pretty good for a driving street performance Pontic.
Ed
jackdaniels
Post by jackdaniels » Tue Oct 03, 2006 5:39 pm
Ed-vancedEngines wrote:His rear end should be ok, if it was assembled and set up right.
Ed
yeah, specially in Guatemala, :lol:
hes been puting this car together but now hes trying to bo double sure of not doing anything wrong...
So its pretty much ok then?
thanks Ed
Cobra
Post by Cobra » Wed Oct 04, 2006 10:43 am
Alot of maybes in your post. Try to get accurate figures on car. Interesting slick size! Make sure tires will fit car! Good luck!
MileHighMan
Rear end
Post by MileHighMan » Wed Oct 04, 2006 9:00 pm
Daniel. I ran a 8.5 10 bolt in my 76 camaro to an et of low 10.90s@ 124mph. I also ran a 10 bolt to 11.36 with a stock posi. Both with stock 28 spline axles. No transbrake. The car weighed 3350lbs. Don't underestimate the ten bolt. It's stronger than you think. Good Luck, Dan.
jackdaniels
Re: Rear end
Post by jackdaniels » Thu Oct 05, 2006 4:38 pm
MileHighMan wrote:Daniel. I ran a 8.5 10 bolt in my 76 camaro to an et of low 10.90s@ 124mph. I also ran a 10 bolt to 11.36 with a stock posi. Both with stock 28 spline axles. No transbrake. The car weighed 3350lbs. Don't underestimate the ten bolt. It's stronger than you think. Good Luck, Dan.
Hey thanks..
I ll let my friend know...
And thanks to everyone else :D
