Most efficient axle
Transmission to Rear-end
Supershafts
Re: Most efficient axle
Post by Supershafts » Mon Mar 21, 2011 6:31 pm
Save yourself time and money and keep the 30/35
I race my jeep and i built a 44 for it, still sitting on the stand that 35 hasn't broke anything, drag racing, road racing, oval racing... 400hp or 600hp....nothing hurts it...
We Race, We Vote!! Limotorsports.org
Supershafts.com
The Dark Side of Will
Location: In the Darkness, where Fear and Knowing are one
Post by The Dark Side of Will » Tue Dec 12, 2017 8:45 pm
Back from the dead!
I had forgotten about this thread until it showed up as I was searching for something else.
I mentioned that I ended up with a NON-C-clip Dana 44 from an '87 Wagoneer with 3.54 gears. Score!
Here's the axle cleaned up.
And then I dumped most of a can of gloss black epoxy spray paint from McMaster-Carr on it:
Separated the caliper brackets from the dust shields; somehow forgot to snap a "blasted" pic. I'll grab a "painted" pic in a couple of weeks after I get back from London. you can see the modded bolt patterns in both.
Post by The Dark Side of Will » Tue Dec 12, 2017 8:47 pm
The original Dana 44 non-clip hub end component stack:
From left to right: backing collar (not sure why it's not touching the bearing...), bearing, seal, bearing retainer.
Modified stack: backing collar, new bearing, seal, spacer ring, bearing retainer
And the whole shebang installed, including brake caliper brackets and dust shields:
The left axle has pretty decent pitting on the seal surface and needs a speedy sleeve. If that hadn't been the case, I'd have put both together tonight.
Post by The Dark Side of Will » Tue Dec 12, 2017 8:51 pm
The front end for this car is a Dana 30 IFS with 3.54 gears from a 4 cylinder Eagle that I rebuilt stock.
Here's using electrolysis to clean up a really munged up diff.
From this:
From this:
To this:
via electrolytic rust removal.
From this:
Here's the inside of the housing... haven't cleaned it yet and it's pretty nasty.
To this:
Was just a matter of cleaning it up in the parts washer
I've pretty much decided on an Eaton e-locker for the D44 rear and a Detroit True-Trac for the D30 front. I am hesitant to use a locker on the D30 front because it may cause me to frag axles... although the tiny Eagle front driveshaft is probably the first thing I'll turn into a pretzel or just snap.
