Cam For Alcohol???
BEDNAR1320
Cam For Alcohol???
Post by BEDNAR1320 » Tue Nov 15, 2011 9:40 am
I have a question on cam selection for an alcohol fueled 565 BBC drag engine. One well known cam company recommends keeping the exhaust duration on the short side to keep heat in the chamber (290@.050-320@.020). While a well known drag race engine builder with experience in alcohol fueled engines recommends the opposite, he wants exhaust duration around 305@.050-335@.020. This motor has conventional heads and 14.5 CR and is injected (Rons) in a dragster. Any thoughts?
AM I THE ONLY ONE WHO WOULD RATHER BE ON THIS FORUM INSTEAD OF WORKING LIKE I'M SUPPOSED TO BE RIGHT NOW?
donc
Re: Cam For Alcohol???
Post by donc » Tue Nov 15, 2011 11:59 am
I used a similar cam as the cam grinder recommends,application was blown 468 bbc,set record with it.
BEDNAR1320
Post by BEDNAR1320 » Tue Nov 15, 2011 2:21 pm
Dirrerent deal with a blower.
CamKing
Post by CamKing » Tue Nov 15, 2011 2:33 pm
We find we can normally run about 4 degrees less with alcohol.
I believe that since the exhaust temp is down with the alcohol, the exhaust gasses do not need as much time(duration) to evacuate the cylinder.
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
BEDNAR1320
Post by BEDNAR1320 » Tue Nov 15, 2011 4:21 pm
Thank you Mike, I just can't see running 15deg. less duration because of using alcohol for fuel.
ALKYAL
Post by ALKYAL » Wed Nov 16, 2011 5:55 pm
Does some of this go back to a magazine article a few yrs back? Dragster 555cu in? Alky carb-big Duke heads. Engine wouldnt pull and or had HS miss. Thay crutched it up by adding Ex duration. And Every one went home happy!
Some people are so stupid that they dont even know it! - by a famous Hillbilly
Post by 69427 » Wed Nov 16, 2011 11:32 pm
A related question to the original posters set up, dose the mechanical fuel injection system have any influence on the cam design?
Thanks
Tom
Burns Family Racing
69 Camaro 3350# 1.30 60' 6.14 @ 111.15 still tuning
427 BBC oval port by S&S Speed
T400 by Sepanek transmissions, Dynamic converter
BlitzA64
Post by BlitzA64 » Fri Nov 18, 2011 10:58 am
I just got camshaft specs on Ed Pink Toyota and Mopar Midget Engine Camshafts as well as a Roush Engineered Cam for a Ford SC1 Headed Midget Engine. All of the above were virtually identical although speced by different folks. For what it's worth, the Intake/Exhaust spread is 11*to13* on all of them. I thought that if the exhaust gases were colder they move slower therefore requiring more exhaust duration? Also with Injection the fuel curve tends to get rich on the top, even with a high speed bypass cooling exhaust gasses and slowing them more?
CamKing
Post by CamKing » Fri Nov 18, 2011 11:58 am
Think about what's going on.
The mass going into the cylinder is the same, but it's not heating up as much.
What's different about a pound of air at 1,200 degrees compared to a pound of air at 1450 degrees?
BTW, I just looked at a bunch of midget and Sprint car cams, both my designs, and other cam companies designs. The biggest spread I found was 8 degrees at the seat(SB2 headed midget). The shortest was a zero spread(D3 headed midget).
The mopar sprint engine I was looking at had a 2 degree split from another cam company, and I mine was a 4 degree split.
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
BlitzA64
Post by BlitzA64 » Fri Nov 18, 2011 12:07 pm
Ahhhhhhhh, SEAT! I was looking at .050". I will look at the files again when I get home. I had the Roush one ground by LSM for my -12 engine a month or so ago. I was in a rush and when I got in touch with you Mike the timeline didn't fit. I did just buy a Ford SC1 headed engine an have no idea what cam is in it........
BlitzA64
Post by BlitzA64 » Fri Nov 18, 2011 12:19 pm
Mike, I just E Mailed you the TRD/Toyota cam chart........
0ldsm0bile 81
Post by 0ldsm0bile 81 » Thu Jan 15, 2015 7:28 pm
looking for cam specs on 565 bbc with sv1 carb 1180 cfm . head flow 470 and 335 . on methenal . car weighs 3100 w driver ,glide 4.11 gears. : 14/1 comp
