" You might be a head porter if..."
Open
groberts101
Re: " You might be a head porter if..."
Post by groberts101 » Wed Mar 21, 2018 11:33 am
PackardV8 wrote:
Wed Mar 21, 2018 11:31 am
Your dreams at night are of having X-ray vision and of long shank burrs which can operate at a 45-degree angle.
I thought that's what bandsaws and welders were for, Jack! Sorry.. couldn't resist. :lol:
cuisinartvette
Post by cuisinartvette » Wed Mar 21, 2018 12:31 pm
a removeable port roof
BILL-C
Post by BILL-C » Wed Mar 21, 2018 12:40 pm
You have a mountain of cylinder head corpses you have cut into pieces with the band saw to see what the inside of the waterjackets and port walls look like. AND you can identify them by their shape with your eyes closed!
Carlquist Competition Engines
HeinzE
Post by HeinzE » Wed Mar 21, 2018 1:22 pm
After loosing flow after every attempt to improve it you swear off ever doing porting ever again...and then can't wait to get up the next day to try it again.
BOOT
Post by BOOT » Wed Mar 21, 2018 1:35 pm
racear2865 wrote:
Wed Mar 21, 2018 10:05 am
I have found duck tape works best.
reed
Works good on hoodie pockets as well!
#xx Your index fingers have no prints
statsystems
Post by statsystems » Wed Mar 21, 2018 1:38 pm
If your hand writing took a dump because your hands are numb from grinding.
If you blow your nose and enough iron comes out to cast an intake manifold.
If you reach into your pants pocket for your keys and get a sliver.
GARY C
Post by GARY C » Wed Mar 21, 2018 1:43 pm
Scotty wrote:
Wed Mar 21, 2018 7:20 am
Yep ....what about when they take to your eye with the little grinder, thats fun too.
Went through that on my first set of heads so I built a lighted port box that connects to the head and hooks to a shop vac so their is no loose metal to deal with, it's harder to move the head around but I don't do it for a living.
Newold1
Post by Newold1 » Wed Mar 21, 2018 3:51 pm
You have ringing in both ears!
You keep saying WHAT during conversations with others!
You can't pass thru the TSA detection lines when trying to board a plane!
You shop clothes tend to sparkle in the light!
Your neck is so stiff it will hardly move quickly up or down or left to right without crackling or popping!
You just keep grinding and pounding during se* after climaxing !! =D>
Post by MadBill » Wed Mar 21, 2018 4:49 pm
EVERYTHING looks to need porting*. (I'm no pro, but speaking of shop vacs, when I went through my '6.25 HP' Sears, I picked up almost 20% flow and the sound level went down a ton. The big gain was filing the square-edged 0.020" thick impeller vanes into crude airfoils.)
*"To the man with a hammer, everything looks like a nail."
hoodeng
Post by hoodeng » Thu Mar 22, 2018 1:19 am
During an MRI on your hand they stop the procedure and ask if your hand is getting hot ,and you tell them "nah , not really" ,,they finish the MRI and tell you you have Christmas lights in your hand , the ferrous bits get hot and the alloy bits don't.
My tinnitus is the same frequency as my die grinder.
Cheers.
Carnut1
Post by Carnut1 » Fri Mar 23, 2018 3:07 pm
If you are ocd, adhd, and a perfectionist.....
The Air Force Thunderbirds are practicing overhead, I need to work on being a perfectionist. Those pilots are just amazing!
KnightEngines
Post by KnightEngines » Fri Mar 23, 2018 9:15 pm
You can't keep a snout bearing in your grinder - just shat another one.
Grinder gives a little hiccup, I think 'ah shit, only got about 2 hrs grinding left in this head' & dose the crap out of the bearing with air tool oil, spin it hard & shrug - what's the worst that can happen?
Bearing locks up 10 min later, dang.
No spares left either.
& I've robbed all the right size bearings out of my dead grinder stash.
Have to wait till monday now & I was just in the groove & looking to finish up.
Kenova
Post by Kenova » Sat Mar 24, 2018 12:42 am
https://www.youtube.com/watch?v=LlXlhxCwxv8 :lol:
If you don't have the time to spare, jump to 16:40.
Ken
Over the hill but still learning!
Retaining it is the hard part.
Zmechanic
Post by Zmechanic » Sun Mar 25, 2018 11:04 am
Cheers.
I had a radiologist darn near deny me an MRI once he read my form... I convinced him I'd be fine because I mostly machined aluminum.
