2006 focus low volume air out hvac vents
Evap and heater core leaking were replaced. Blower replace worn bearing. Too much current. No volume air out blower resister hole when resister is out. All vents inlet and out are free flowing. .2 volt drop too blower moter.
Re: 2006 focus low volume air out hvac vents
In cab air filter plugged?
-Carl
-Carl
i recently replaced a blower motor on a chevy venture van, It was a AC delco fan with the matching plug-in to connect to the vehicle with no snipping wires or anything like that. Its a long story but turns out it was actually spinning backwards. We finally snipped and reversed the factory wires and had tons of air. It took a long time to figure out because we never suspected something like that.
Brian
Brian
