2006 focus low volume air out hvac vents
Open
maxc
Post by maxc » Thu Mar 30, 2017 10:06 am
Evap and heater core leaking were replaced. Blower replace worn bearing. Too much current. No volume air out blower resister hole when resister is out. All vents inlet and out are free flowing. .2 volt drop too blower moter.
In-Tech
Re: 2006 focus low volume air out hvac vents
Post by In-Tech » Thu Mar 30, 2017 6:43 pm
In cab air filter plugged?
-Carl
prairiehotrodder
Post by prairiehotrodder » Fri Dec 07, 2018 2:08 pm
i recently replaced a blower motor on a chevy venture van, It was a AC delco fan with the matching plug-in to connect to the vehicle with no snipping wires or anything like that. Its a long story but turns out it was actually spinning backwards. We finally snipped and reversed the factory wires and had tons of air. It took a long time to figure out because we never suspected something like that.
Brian
