engine core price
Open to topics unrelated to Speed-Talk.
No politics. No religion topics.
mdabbott2009
engine core price
Post by mdabbott2009 »
What's the Going rate on
350 4 bolt std bore
400 2 bolt 509 std bore
5.3 block and crank heads
402bbc block heads and crank
454 block bored .30 2 bolt
6.0 block spun cam bearing
882 heads
427 crank
Re: engine core price
Post by pdq67 »
You are asking for info that will get into the guys pockets if they tell you!!
Especially the f** "Flippers" on here!!!
But the real HONEST answer is what ever you can get for the stuff over and above scrap metal tonnage prices!!
Cast-iron, steel, and aluminum prices.... Not much copper in our hobby that I know of since the Model T days..
PackardV8
Post by PackardV8 »
What's the going rate on:
350 4 bolt std bore - $400
400 2 bolt 509 std bore - $400
454 block bored .30 2 bolt -$400
882 heads
427 crank - $125
Zmechanic
Post by Zmechanic »
PackardV8 wrote:What's the going rate on:
882 heads
427 crank - $125
I just sold a 509 block in great shape, std bore, probably clean up at 0.010 over actually for $275 (I told the guy who bought it to only bore it as much as needed to clean it, since SRP makes OTS 0.005 and 0.010 pistons for it). Guess I should have charged more, but I wanted it gone.
BBCFAN
Post by BBCFAN »
So who is buying engine cores?
machinedave
Post by machinedave »
mdabbott2009 wrote:What's the Going rate on
350 4 bolt std bore
882 heads
427 crank
350 4 bolt std bore $100
400 block $200
5.3 block, crank and heads $150
492 block, crank and heads $200
454 block about $300
6.0l block with spun cam bearings $0
882 heads $50 pair
427 crankshaft maybe $75 for turntable core.
There are so many cores in my area that I have some people just dropping them off for free.
PackardV8
Post by PackardV8 »
machinedave wrote:350 4 bolt std bore - $100
[/quote]
Hi, Dave,
Start loading them up, five to a pallet. We'll take a semi-trailer load at $100 per.
machinedave
$100 is about the most that I can get for them. The last one I bought was at a swap meet. The guy had a std bore 350 4 bolt main with a a $20 price tag on it. It was the end of the day and I looked it over and he said "I don't want to take it home, just give me $10". I bought it , sent it out for a bake and shot blast blast and tried to sell it for $200 and it took almost 2 months before anyone would even call on it.
machinedave
Where I live vehicles rust from our harsh winters and that leaves a lot of good cores available for next to nothing.
Post by pdq67 »
Where do you get your used 502" BBC core blocks instead of buying a new one?
Fordracer347
Post by Fordracer347 »
pdq67 wrote:Where do you get your used 502" BBC core blocks instead of buying a new one?
Marine salvage use, these days good luck finding them and check for rust.
GPM Race Engines
Custom Machining, Dyno Service, Automotive & Marine
http://www.gpmraceengines.com
Facebook: https://www.facebook.com/pages/GPM-Race ... 8632920064
Twitter: @ GPMracengines
Post by pdq67 »
Thanks Ford,
In other words, I should have asked, "Who will sell a new 502" bare block at a good price?"..
If I think S&H is too high, I will figure out how to get it to me, my way..
cv67
Post by cv67 »
For cores that cheap send me a pm
mdabbott2009
Wow wish I lived closer to some other buyers I ended up with about 650-700 from local machine shop. Ended up trading out labor and parts to redo my 781 heads
