A New Engine Contest
Open
Big Speed
Re: A New Engine Contest
Post by Big Speed » Sun May 15, 2016 3:30 pm
Has the location been established yet?Bill C.
Ceralli Competition Engines & Checkered Flag Machine
Racing engines , CNC head porting and induction development
http://www.checkeredflagmachine.net/
Bulletbob
Post by Bulletbob » Sun May 15, 2016 10:23 pm
We have established several locations that are available to host the competition. These locations are centrally located in the U.S. to hopefully be convenient for everyone.
WeingartnerRacing
Post by WeingartnerRacing » Mon May 16, 2016 9:53 pm
I would like multi carb, solid roller cam, 14to1 compression, and conventional port layout heads.
Eric Weingartner
Weingartner Racing LLC
918-520-3480
www.wengines.com
Walter R. Malik
Post by Walter R. Malik » Tue May 17, 2016 12:35 am
WeingartnerRacing wrote:I would like multi carb, solid roller cam, 14to1 compression, and conventional port layout heads.
In my opinion ... that is exactly what "Extreme STREET" should have been in the first place, with flat tappets, a "0" lash lift rule, 10.5/1 compression and a cast single 4 barrel type, (carb or F.I.), for regular "Street".
Those would encompass most actual street vehicles of ALL brands.
Post by gmrocket » Tue May 17, 2016 11:40 am
anything that allows some creativity is a good thing.
i would like to see a class 350/360 cube class thats run on premium pump like 93/94. factory iron heads, to showcase the engine builders head work. 10.5 or 11 to 1, single 4150 , 3k to 7k epoxy allowed, any ring dimensions you want, and any bore/stroke :wink:
every manufacturer has an engine in this cube range. AMC, Buick, Olds, Pontiac, Chrysler, Chev and Ford. but it would be soooo boring without aluminum heads :lol:
Bulletbob
Post by Bulletbob » Tue May 17, 2016 12:02 pm
This is why we are working with the idea of the possibility of two classes. This could be something like an extreme and street. We are wanting the competition to be along the lines of what you are thinking. Example: I am not interested in micro-managing piston ring size but if the engine was "street" then there should be cylinder heads that are commercially available. Same thing with the intake, commercially available. But, if the engine was in the extreme, then I could expect to see a fabricated intake.
Over the past week, I have been surprised at the response from the idea of a new competition. At this time, keep the phone calls coming to myself and Greg as we are gathering many ideas for the rules. "WE ARE LISTENING", so keep the ideas coming and if you know of others that want to participate, please forward them to us. We are looking to have an Engine Competition and Reunion because we all love to compete and at the same time share our thoughts and ideas.
Thanks
WeingartnerRacing
Post by WeingartnerRacing » Tue May 17, 2016 1:47 pm
I have zero interest with cast iron heads. I do enough for circle track. It ends up costing much more than aluminum.
I want cast intake and heads and whatever welding or epoxy you want. The class should be extreme bracket motor because it is affordable then street class.
Eric Weingartner
918-520-3480
www.wengines.com
Post by gmrocket » Tue May 17, 2016 2:48 pm
WeingartnerRacing wrote:I have zero interest with cast iron heads. I do enough for circle track. It ends up costing much more than aluminum.
i agree with you on that...but it eliminates non mainstream builds. thats why they are very rare sight at the EMC...especially in the bigger cubes, they are non existant... the EMC has a real phobia against smaller cubes lately. but i do see they have a 350 cube minimum for the small block class.
when your stuck using as cast externally,, and no epoxy or welding internally, on a non mainstream engine where there in one intake and one head manufacturer to pick from..what do you do? i dont go there to make friends and schmooze, its more fun to compete and not make a fool of yourself.
E.R. Racing
Post by E.R. Racing » Tue May 17, 2016 3:34 pm
Where is this going to take place?
Bulletbob
Post by Bulletbob » Tue May 17, 2016 9:56 pm
There are several locations we have secured in the central US which should be convenient for all. We will finalize the location within the next several weeks. Each of these facilities have the dynos, man power, and work area great to host our competition.
Walter R. Malik
Post by Walter R. Malik » Wed May 18, 2016 12:01 am
Sounds like there will be enough fodder for at least a few years of "real street" and "extreme Bracket" competitions... :)
Bulletbob
Post by Bulletbob » Thu May 19, 2016 10:01 am
That's right, should be enough for everyone for many years of competition.
Keep the ideas coming as we are in the process of trying to compile a set of rules
Thanks,
Bob
900HP
Post by 900HP » Thu May 19, 2016 10:02 am
I'm interested in this as long as you keep the FE Ford people out :mrgreen: I'm sure Hot Rod has their reasons for banning this disreputable group of people :lol:
................. Barry, give me a call when you have a minute.
Throttle's Performance
(701)893-5010
https://www.facebook.com/pages/Throttle ... 1996281602
Barry_R
Post by Barry_R » Thu May 19, 2016 12:28 pm
Hot Rod let me in - some famous rich guy decided to only enter one engine and made a place for the downtrodden, maligned tractor engine guy...
I might enter in two contests if they have classes I can compete in - like Street Slow, and Street Poke
Survival Motorsports
www.survivalmotorsports.com
900HP
Post by 900HP » Thu May 19, 2016 12:39 pm
Barry_R wrote:Hot Rod let me in - some famous rich guy decided to only enter one engine and made a place for the downtrodden, maligned tractor engine guy...
I never knew FE stood for Farm Equipment................. it all makes sense to me now! :lol:
(701)893-5010
