1969 Pontiac 400
Open to topics unrelated to Speed-Talk.
No politics. No religion topics.
Dboser53
1969 Pontiac 400
Post by Dboser53 »
Dear Forum,
Can anyone advise if machining is required to install Comp 995-16 valve springs on a 1969 Pontiac 400 with No. 48 Heads and if so is there detailed requirements on the web?
Thanks
tjs44
Re: 1969 Pontiac 400
Post by tjs44 »
Im pretty sure we had to cut the seats on the set we did.I do know we got rid of the factory 2 pc valves and went to the RA IV length valves.Do not run the stock valves!Tom
Post by pdq67 »
And another thing is check the diecast aluminum front timing cover assy. that also mounts the water pump for corrosion. If it corrodes and leaks anti-freeze, it goes right into the engine.
My B-I-L had one corrode on his '67 'Bird's 400 engine way back years ago is how I know this may happen.
