Stan Weiss wrote:Just a one question multiple choice quiz.
I have a stick shift car that has just moved away from a traffic light and is rolling at 5 mph. I floor the gas and accelerate up to the red line. If I data captured RPM and acceleration in G's, where would the point of maximum acceleration be?
1) can not tell
2) peak torque
3) peak hp
4) red line
Stan
The correct answer is 2.
With that said, do not let this lead you into thinking that the goal of acceleration is based on engine torque. Acceleration is and always has everything to do with engine horsepower. As been already said, it is rear wheel torque, not engine torque that determines acceleration.
Consider a car with a CVT (continuously variable transmission) that has the ability to continually adjust gearing in the trans to keep the engine at one continuous rpm all the way down the track. Run the car down the track at a continuous rpm two times. Once at peak torque and once at peak horsepower. Now I ask, which rpm will the car accelerate the quickest at. Do a little math and the answer is obvious.
An engine has the greatest potential to do work in the shortest time at peak horsepower, not peak torque.
What gets confusing to people is when you do the math, you will find the the highest wheel torque in "one gear" always happens at peak torque, but if you re-gear, such as a downshift, that takes you to peak power, you will find a higher rear wheel torque figure.
If you are in a gear, such as 4th, and you nail it at peak torque, then you do a downshift that gets you right to peak horsepower, acceleration is increased.
ARN
