Bought a new camshaft - must be a new design for BBC
Bummer!
Even cast cams take a lot to snap them if they are properly made.
I hope there was more stuff in that box and especially more firm packing material.
The "Fragile" warning was inside, not on the outside of the carton. Evidently the carrier x-rayed, found the "Fragile" and then mishandled it.
FWIW, I don't recall seeing "FRAGILE" (fra-GEE-lee) labels on cam boxes. What brand?
Cigar if you immediately recognize the source for the "fra-GEE-lee" pronounciation.
Jon
Jon
[i]"There are some people who, if they don't already know, you can't tell 'em."[b]....Yogi Berra[/b][/i]
[i]"Being able to "think outside the box" presupposes you were able to think in it." [b]--Bob Lutz[/b][/i]
I was hoping there weren't air pilows in there. They suck for packing dense parts. We've seen heads packed with air pillows that needed hundreds of $ worth of welding and machining to fix the damage from shipping. You might just as well tie a tag to the casting and not even pack it in a box. At least they wouldn't be banging into each other. Cams in a cam box and no other packing usually get thru unscathed.Truckracer wrote:In the box with the cam was some intake gaskets, bottle of cam break in lube and the lifters. Every thing was on the bottom of the box with those liitle air pillows stuffed in the top to take up the slack...
It's a Summit brand cam..
I hope it wasn't a Summit shipment but the paperwork looks familiar.
Even in a recession it's hard to find good workers!
Jon
You'd think Summit would take it out of the Camshaft Machine Company box, and re-box it. That's the box the cam was shipped to Summit in. They're not the best quality.
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
Jones Cam Designs
Denver, NC
(704)489-2449
Sorry,fastvette wrote:As in the core or the grind job?CamKing wrote:They're not the best quality.
The Box is not of the best quality.
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
Jones Cam Designs
Denver, NC
(704)489-2449
Shipping cam and lifter kits can be an adventure.
Just think how far you can throw a camshaft "javelin style" into a semi-trailer or UPS truck. That cam is a battering ram and will try bust out of the box.
I sold hundreds of cam kits over a two year period (my apologies to the real cam guys) Packaging was a big issue as I did not have much control over shipping materials.
The best the shipper could do with materials on hand was tape and reinforce the cam box, package the lifters in boxes of four, then pack the triangular style UPS box with the processed cardbord packing. There was still too much damage.
Mike Jones knows how to pack a cam and lifters. His packaging looks very tough.
Re: Bought a new camshaft - must be a new design for BBC
Ouch! UPS really had to put a hurtin' on that box to do damage like that, Truckracer! Hope they make it right for you and without your having to wait months for a resolution.Truckracer wrote:Easier to install if they are two piece..
The only cam I ever busted was my own fault. 1967 - Home on leave, partied too much, missed a shift in my '57 Ford and floated the valves in a 292 Y-block engine whilst racing my buddy, who had a '58 Chevy with the 348 tri-power engine.
Got the jump on him off the line. I was pulling him half a car length. Wound her up too tight. Blew the 1 - 2 shift. Put a valve through a piston and broke the cam in half right behind the 2nd lobe. Yea verily...... It sucketh much!
Best regards,
Harry
Yet UPS still breaks 2 or 3 a year for me.Keith Morganstein wrote: Mike Jones knows how to pack a cam and lifters. His packaging looks very tough.
The roller cams just get bent, but it really doesn't take much to break a cast iron cam.
I just gave a demonstration for a guy that work for me. We needed to send a piece of a cast cam to a metallurgist, and he was going to saw it.
I took the cam, held it straight out at arms length, and dropped it. Presto, a nice clean break right after the second journal.
I had a customer that was so tired of UPS bending and breaking his cams, he sent me a wooden box he made just for shipping his cams.
I like the 6" tubes with the foam inserts that Comp Cams uses. They're a little much for the average cam, but I bet they don't break any.
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
Jones Cam Designs
Denver, NC
(704)489-2449
Caterpillar uses a cardboard and wood combination that works well. Two sides and the ends are wood, the two other sides are heavy cardboard stapled on.CamKing wrote: I had a customer that was so tired of UPS bending and breaking his cams, he sent me a wooden box he made just for shipping his cams.
