2009 EngineMasters, What's new?
Dan, re the mixture variation, I have seen this on Dellortos when using ram tubes of more than say 2-3" length. In one case we had to go up 7 sizes on mains and up 4 on air correctors to compensate when 3" tubes were replaced by 8" ones (I believe there are special extended length aux venturis for use with ram tube that minimize such acrobatics.)
Even though the average power is likely to be down, you could try a pull with short or no air bells, just to see if it quells the AFR variations.
Also, the emulsion tubes usually affect the very bottom end of the range, especailly tip-in. David Vizard's method for tuning them is to place contenders on a table with the tops 'as installed' facing towards you. Now look at the size and placement of the holes. The further away from you, the higher the RPM they affect and the greater the area of holes in that region, the leaner the mixture will be.
One last note: I recall discussions some time ago re venturi size for your app, and while I don't doubt that some have had sucess with chokes of 90% or more of throttle bore diameters, many havec come to grief thus. It might be worth a pull or two with chokes of no more than 80% of TB diameter to see if that improves the fuel curve.
Thanks, Bill
We're pretty much out of time/ideas/enthusiasm/money, etc. lol
Going back to the pump one more time on Tuesday to check out some different exhaust systems. If they provide no change, we feel we can probably eliminate the headers as the cause of the lean spike.
I'll show up with a shorter (256 vs. 266) cam that we can plug in if nothing else helps. I suspect that we might have too much cam, but on the other hand, peak power is at 6500, and I can't imagine that the camshaft is causing a lean spike.
Danny
Danny
I recall when I did a V12 with 6 x Weber IDF's, once we had a 'bit of cam' in it it would not get on the plane with the ram tubes at all, (boat application).MadBill wrote:Dan, re the mixture variation, I have seen this on Dellortos when using ram tubes of more than say 2-3" length. In one case we had to go up 7 sizes on mains and up 4 on air correctors to compensate when 3" tubes were replaced by 8" ones (I believe there are special extended length aux venturis for use with ram tube that minimize such acrobatics.)
We had tried every combination we had at the river and no success, even different accelerator pump arm positions, one run I didn't refit the ram tubes and away it went, came back fitted the ram tubes, it would not get 'on the plane'.
It ran its first few races with nothing on top, then for aestheitics we cut off the tubes and just flared the short casting of the top cover plate.
This engine, V12 Jaguar, had relatively straight inlet ports, at WOT with the valve open you could see the piston and/or bore.
It always suffered with fuel standoff.
The Weber 44 IDF's had machined oversize venturi's.
X2!MadBill wrote:Dan, re the mixture variation, I have seen this on Dellortos when using ram tubes of more than say 2-3" length. In one case we had to go up 7 sizes on mains and up 4 on air correctors to compensate when 3" tubes were replaced by 8" ones (I believe there are special extended length aux venturis for use with ram tube that minimize such acrobatics.)
Long ram tubes on carbs can do strange things to carburetion, particularly if the ram tube is not much bigger in diameter than the throttle. Very good chance this is the problem.
I'm also thinking there's something going on in this area.MadBill wrote: One last note: I recall discussions some time ago re venturi size for your app, and while I don't doubt that some have had sucess with chokes of 90% or more of throttle bore diameters, many havec come to grief thus. It might be worth a pull or two with chokes of no more than 80% of TB diameter to see if that improves the fuel curve.
What is the venturi size you're running?
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
Jones Cam Designs
Denver, NC
(704)489-2449
I'm sitting at a race in Budds Creek, MD. Waiting for the rain to stop. Wishing I was at home working on the Enginemasters entries. Both engines have fuel curves ( o2) that look like the Swiss Alps. At 3600-4000, both engines go down to 9.5/1 air fuel. Both tunnel rams with 4500 dominators. I think that this is the point where the manifold lengths are such that they are on the wrong side of the pulse. Or the manifold and headers work against each other. It's not a carb issue. A bigger plenum would help, but I can't make it any larger by the rules. One thing that makes it worse than a 4bbl, is that all the runners are the same length, so they all come into and out of sync at the same time. 1 week left. ... Kaase
Hello Mike
I believe that they're 48's. On a previous session (last year's engine) we tried removing the vents. No joy.
I'm opening up the choke on the merge collectors that we have been using. I made them 2.500", but on the OD. That would make them around 2.375" on the ID. I don't know how choke points are described, but suspect that 2.375" might be a little small.
I'll open them up to 2.750", as soon as someone smart 'splains whether it's ID or OD. lol
My current thinking is that bigger is probably better than smaller (if you're as lost as us), and will probably opt for 2.750" ID
Danny
Danny
Hello Jon
You have such an honest face, and are such a likable guy, that I'd like to believe you. lol
But my evil side figures that you're at about 12.5 to 12.51 start to finish.
Really looking forward to the Challenge. There should be more interesting things there than in a college cheer leader room.
Danny
Danny
Well, there goes my only idea. I calculated it needed 49's, so that's not the problem.dan miller wrote: I believe that they're 48's.
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
Jones Cam Designs
Denver, NC
(704)489-2449
Hello Mike
What's your take on the cam timing needed in a deal like ours?
We currently have 266@ .050" with 108 lsa. Several folks have offered that the cam was the probable cause for the lean spike. I dunno. However, I sent a larger cam to Doug Engle yesterday, and he ground it to a 256 (same lift and lsa) and headed it back my way.
So if worst comes to worst, and we still can't get a handle on it when we go back on the pump on Tuesday, we'll stab it in. If it has the same or more power, we'll leave it, if not, out it will come.
We're leaving Thursday morning, so I'd really prefer not to do the cam swap-o rama.
I've also heard that dual pattern cams with less exhaust duration are recommended for Webers. Any feel for that? We typically run single pattern cams in all our engines.
Thanks, Danny
Thanks, Danny
What's the stroke in the engine?
We always ran single pattern or 4 degrees longer on the exhaust.
We'd run the same cams we ran with the mechanical injection.
For some reason, I remember most of them liked a 108 LSA.
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
Jones Cam Designs
Denver, NC
(704)489-2449
Ha - Ha - Ha,
After only a few pulls with a tunnel-ram manifold my engine had an almost flat 02 Fuel curve which varied only about 1 ratio from beginning to end.
Of course it also didn't have nearly enough points to even make any noise about - I'd gladly take a mountainous fuel curve and a lot of points, LOL.
To be honest, I really don't understand the choice of a tunnel-ram for this application.rmcomprandy wrote:Ha - Ha - Ha,
With having to make power from 3,000-7,000, I would think you'd give up a lot on the bottom, and before it started helping on top, you'd be up against the restriction of the mandated mufflers.
I have a feeling that the engines that do well will have a 4.040"-4.125" bore. a 3.75"-3.875" Stroke, a single plane manifold, and a single 850 carb.
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
Jones Cam Designs
Denver, NC
(704)489-2449
