11.000 rpm: what would you do...
Open
Postby TwinTurboM3 » Thu Aug 27, 2009 7:21 am
What would be on your list if you would like to rev 11.000 rpm?
Engine inline six cylinder
Stroke 91 mm
On the list items:
very strong valve springs capable of opening and closing valves @ 11.000 rpm.
carillo rods with carr bolts.
light weight pistons forged. with heavy duty piston pins.
titanium retainers
a good light weight tripple plates clutch kit.
all assembly balanced and blueprinted.
dry sump oil system.
What would you add to these?
941 whp Dynamics Shootout (low boost)
TwinTurboM3
Postby AdioSS » Thu Aug 27, 2009 8:26 am
why is the RPM capability so important? What are your power goals?
Getting enough air and fuel into the engine would be pretty high on my list.
I've noticed a guy on one of my local boards often talks like that. He comes from mostly 4banger import stuff, and he's getting an LS1 built for an RX7. He seems to care more about what his engine builder said the RPM range would be than how much power he'll make. :roll:
Cheston Phillips
96 Impala SS
05 Silverado
AdioSS
Postby CamKing » Thu Aug 27, 2009 8:51 am
That's an average piston velocity of 6,569-fpm.
I hope you're not planning on running it for more then a few seconds.
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
CamKing
Postby PackardV8 » Thu Aug 27, 2009 10:08 am
X3 on the questions/cautions above.
is neither affordable nor durable.
It's been said here many times, but RPMs are the most expensive horsepower there is. IMHO, for conventional production-based engines, as the RPMs go up past 8,000 RPMs, the cost per durable horsepower goes up logrithmically.
thnx, jack vines.
P.S. - we're about due for another of these threads, "I just found a 283" steel crank and am going to put it in a 350" block and build a 10,000 RPM screamer, because I like to beat people by using little cubes."
PackardV8
Postby Stan Weiss » Thu Aug 27, 2009 10:19 am
CamKing wrote:That's an average piston velocity of 6,569-fpm.
Pro Stock get up in that area and they only cost about xxxk per. :lol:
Stan Weiss
Postby mtkawboy » Thu Aug 27, 2009 10:34 am
Good luck keeping a flywheel on an 11,000 RPM 6 cylinder with the harmonics problems
mtkawboy
Postby CamKing » Thu Aug 27, 2009 10:39 am
Stan Weiss wrote:Pro Stock get up in that area and they only cost about xxxk per. :lol:
They build and dyno one 3 doors down from my shop.
On a clear day, you can actually see the Dollar signs floating through the roof, and into the sky. :lol: :lol:
I've got no problem with turning 11,000rpm.
We can do it reliably with a 4valve V8 with a 64mm stroke, and keep the cost under $100K :wink:
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
CamKing
Postby steve25 » Thu Aug 27, 2009 11:50 am
I would move the drivers section of the car to in front of the motor so that above 8k when the engine parts start fly out and off they do not knock you out!
steve25
Postby $um Toy » Thu Aug 27, 2009 12:12 pm
I totally agree that those are high piston speeds, however they are not unatttainable. You did not say what the intended use of the engine was. Is it a drag race only deal? I am currently running a 648 inch BBC with a 4.875" stroke in a pulling truck with max rpm of around 8500. That is an average piston speed of 6900 FPM without problems and we run for about 14 seconds at WOT.
$um Toy
Postby $um Toy » Thu Aug 27, 2009 12:15 pm
Cam King, you must be right aroung the corner from V. Gaines I take it? That must be interesting having a pro stocker so close to home.
$um Toy
Re: 11.000 rpm: what would you do...
Postby Horsewidower » Thu Aug 27, 2009 12:38 pm
TwinTurboM3 wrote:What would be on your list if you would like to rev 11.000 rpm?
An unlimited wallet.
You've got twin turbos, why do you need 11,000 rpm? And I ask that seriously.
Bob
Horsewidower
Postby TwinTurboM3 » Thu Aug 27, 2009 12:54 pm
I dont want anymore as this thread turned into a debate rather than an informative thread.
TwinTurboM3
Postby CamKing » Thu Aug 27, 2009 12:55 pm
$um Toy wrote: I am currently running a 648 inch BBC with a 4.875" stroke in a pulling truck with max rpm of around 8500. That is an average piston speed of 6900 FPM without problems and we run for about 14 seconds at WOT.
A old retired guy in South Carolina just won the Lottery and made $85 million after taxes.
His experience doesn't make any of us any more likely to win the Lottery.
Anything's possible.
If it's my money, I'd rather bank on the probable, over the possible.
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
CamKing
Postby FastFourierTransportation » Thu Aug 27, 2009 1:08 pm
mtkawboy wrote:Good luck keeping a flywheel on an 11,000 RPM 6 cylinder with the harmonics problems
Inline-6 engines have no harmonic problems as they are better balanced than all but a V12, if that.
It's V-6's which have the end-to-end vibration problems. :-k
A theory without experiment is like a painter without sight, but an experiment with no theory is just a 4 year old with paint.
Practical Engineering is finding new and better ways to copy other people's designs.
Postby SWR » Thu Aug 27, 2009 1:08 pm
I'm building a 11000 rpm Cosworth motor with 82mm stroke, and we have had to revise a whole lot of stuff just to even think of reliability.... with a 91mm stroke I'd run it 402 meters at a time, max.
-Bjørn
"Impossible? Nah...just needs more development time"
SWR
Next
Return to General Discussion
Who is online
Users browsing this forum: swatson454 and 2 guests
