What's the "off season"???3V Performance wrote:Vacation???
Thats what the off season is for.
Chinese look a like Little-M block
What off season?? your just use to working for the Cup teams3V Performance wrote:Vacation???
Website is up and running
Machine shop tour
Monthly Specials
Machine shop tour
Monthly Specials
- Wolfplace
What the hell is a vacation???
Vacation
The time you take off to do all the crap you didn't have time to do while working,,,,
Self Employment
The thing we decided to do in leiu of working at a real job so we could work longer hours to make less money
Vacation
Self Employment
Mike
Lewis Racing Engines
4axis CNC block machining
A tour of my shop
The Dyno
And a few pics of the gang
John Wayne
A tour of my shop
The Dyno
John Wayne
Talked to a shop owner today that had 2 Marine BBC's come in becasue the heads were leaking water that another shop had built, These engines had 35 hours on them and the POCOMP 320 RUNNER HEADS were completely rotted out.
Another fine quality chinese product.
Machine shop tour
Monthly Specials
Machine shop tour
Monthly Specials
I bet they flowed some big numbers though! With throats that are 94%! viewtopic.php?t=17964&start=30CNC BLOCKS wrote:Talked to a shop owner today that had 2 Marine BBC's come in becasue the heads were leaking water that another shop had built, These engines had 35 hours on them and the POCOMP 320 RUNNER HEADS were completely rotted out.
Denis
Trump might screw us
HILLARY WILL SCREW US
Hey, Carl, were those "POCOMP 320" (gotcha) heads in a salt-water or fresh-water boat?CNC BLOCKS wrote:Talked to a shop owner today that had 2 Marine BBC's come in becasue the heads were leaking water that another shop had built, These engines had 35 hours on them and the POCOMP 320 RUNNER HEADS were completely rotted out.
tom
Pray for a secular future.
We used to speak to tell things , now they tell things to speak.
Si Vis Pacem, Para Bellum
Even if the engine was raw water cooler and in salt water that ain't alot of time to rot them out..
I have some OEM heads here with several hundred hours that were raw water cooled then converted to a heat exchanger system after 250hrs
They must be real thin to rot that fast but in a way not superizing as they have larger ports ect and cooling passages must be reduced combined with old toyota bumbers to make them............................
Tommachine shop tom wrote:Hey, Carl, were those "POCOMP 320" (gotcha) heads in a salt-water or fresh-water boat?CNC BLOCKS wrote:Talked to a shop owner today that had 2 Marine BBC's come in becasue the heads were leaking water that another shop had built, These engines had 35 hours on them and the POCOMP 320 RUNNER HEADS were completely rotted out.
tom
Salt water but these guys have seen good heads go 7 years in the same water a no problems like this.
Machine shop tour
Monthly Specials
Machine shop tour
Monthly Specials
Oh I think that pics and facts I have given so far are a pretty good so far and today we had a rush job for anther shop and being on vacation this week I willget to the probing of the block next week for sure.catbox wrote:exactly!,..carl seems to have plenty of time for everything but give the facts,...
Unless you can do it faster then maybe you should step up to the bat here.
Right now I am not going to make a dime on this brand-x block and I have spent at least 30 plus hours of emails and phone calls already. And I am behind in the shop but the next time I am on the CNC machine it will go in and be checked out,
If the main line and cam tunnel was the correct size it would have been done a week ago!!!
Machine shop tour
Monthly Specials
Machine shop tour
Monthly Specials
