Pinto spindle issues
phantomfab
Post by phantomfab » Wed Apr 11, 2018 8:23 pm
Hey everyone. I have an issue I have ran into. I'm needing the outer bearing to adapt a metric rotor to a pinto/granada spindle. M12610 I believe is the race I have that fits the hub but I am having the issue of finding a bearing/cone that fits the spindle. Thank you in advance for any help.
Baprace
Re: Pinto spindle issues
Post by Baprace » Wed Apr 11, 2018 8:47 pm
phantomfab, not sure if this helps you, metric cars had two different spindles and the outer bearing was different, if I remember correctly the 1978 was one size and 1979 and up were a different size. The complete spindle with rotor from a 1979 car would fit the 1978 car.
phantomfab
Post by phantomfab » Wed Apr 11, 2018 8:58 pm
The setup is actually on a tre dirt modified with a chevelle stub. I bought pinto spindles and bought brackets for a 10.5 in metric rotor and caliper. The rotors came with the car and I was told they were on pinto so I dles but the spindles had been sold. The inner bearings were still there so I could use the number to buy new ones. But the outer were gone. I read that a a12 bearing kit would fit. However when I went to out it together the inner diamiater was correct but the race wasn't even close to fitting the hub.
phantomfab
Post by phantomfab » Wed Apr 11, 2018 9:02 pm
1.969 outer diameter of the race and a .8656 in diameter is needed. I just can't seem to find a bearing with those specs.
Post by pdq67 » Sun Apr 15, 2018 11:49 pm
Don't know if this will help or not, but here goes.
Chase down an old set of Hollander Manuals and see if you can't cross reference? Public Libraries used to have them on the shelf's but don't know about now?
And maybe TSM and ECI might know? It's been years since I looked for parts like this is all?
