formula for calculating weight change by moving engine
Is there anyway to figure out the change in front end weight by moving an engine back? I would assume you would need to know the wheelbase and weight of the vehicle, percent of weight on front, weight of the engine, distance from the center of gravity of the engine to the front wheels, and the change in that distance but am unsure of what else.
- BillyShope
My car weighs 3150 pounds with me in it. 54% of the weight if on the front. Lets say the engine is about 500 pounds. Moving the engine back 2 inches would change the rear end weight by 3.4% dropping about 111 pounds off the front of my car. That sounds like a lot to me but I've never actually done it. Does that sound right?
2 = 108.1 x P / 100 x 3150 / 500
2 = 6.8103 x P
P = 3.40515
2 = 6.8103 x P
P = 3.40515
- BillyShope
- New Member
Billy,
when using this equation, should'nt transmission weight be a factor also since it will move with the engine?
but then would'nt you have to consider how the eng/trans asm is mounted? because the asm will have a weight bias of its own dependant on its mounting points. ex: motor plate, mid plate, trans mount??
- BillyShope
The equation applies to the NET weight moved.mike walker wrote:Billy,
