Bubstr wrote:A little tip. Usually the cooling systems weak spot is the transfer of heat to the air.Having ducted cool air going threw the radiator is worth it's weight in gold. The only time a fan really does anything is at idle or lower speeds. This is good because your not pushing air threw the radiator with speed and gives you a head start on temp control for when you really make the heat.
Most times if you have a overheating problem, it comes from air not having to go threw the radiator or a radiator with fins too close together or too thick, restricting flow, or shrouds and fan restricting flow of air. I have seen that flat plastic panel that goes from the core support to the bumper cause all kinds of heating problems, when missing. Big holes in the core support can let air around too. It will take the path of least resistance and make a good cooling system second rate. The little air dam on Pontiacs and Cameros can even hurt them if missing. It let air out under and with smaller grille opening, it's enough to over heat one that makes any kind of power.
The bottom line is, you make heat when in the gas and at that time a fan is useless because air should be going faster than the fan, if not, you have trouble.
I dont have an overheating problem. This is a completely rebuilt truck from the ground up. It's a 2000 dodge dakota of all things.
I converted it from EFI to carb. The stock 2 row radiator was junk so I bought a champion 3 row radiator they use in s-10 v8 conversions. It should be able to handle my 408.
Fits very nicely right inside the core support vs the way the old one mounted, so it gives me more clearance for fans and pullies.
And there is no A/C anymore in the way so the rad is open to a direct airpath through the grille.
I understand fully that once I'm moving I'm golden, but here in Detroit during rush hour, or the big woodward cruise we have every year, I may be sometimes sitting in the same spot for minutes at a time and that thought scares the hell out of me.
While the rad is a nice rad, it's odd size of about 23 3/8 core width by about 15 and change inches high leaves me a little screwed as far as what fans I can use.
And also my oldschool 100 amp alternator may likely not put out half that at idle to power smaller dual fans.
I've been working on suspension recently, but I like to think ahead on everything and have a plan. Kinda like how I had a plan when I bought this radiator.
I know the radiator will do the job, but I'm still unsure what to do for a fan. It's likely gonna just be trial and error and I might have to get something stout, or I may be shocked to find a single 16 inch fan will do it just fine.
