dirt track set-up
bono
dirt track set-up
Post by bono »
79 camaro with a body style of 86 camaro 355ci/man-trans/3:73 rear end
My buddy Michel Desjardins has been racing in Cornwall Ontario Canada for the past 3 years and only this year that the car seems to be a little bit better than before.Is there anyone out there who could help set his car right as per track dimensions.anything will be appreciated thank you very much
www.cornwall motor speedway.com
: and click on track info
bubbas
Hello.
Post by bubbas »
#1.What size is the track and banking?
#2.Do you know the final drive of the car?
#3.What size tires is the car presently running including rim offsets and rearend width from center of tires.
#4.What is the front tracking from center of tires measure?
#5.What does the car weigh?
#6.What rear springs and rating as the front springs is the car running?
#7.Does the car have weight jacks on the front?
If you could give this information I will be glad to help you.
Bubba.
Team Owner
Post by Team Owner »
Good questions Bubba, the other one that I would ask is why he isn't using a 9 Inch Ford and 6:00 gears.
