KONI FRONT SHOCKS
CIGARETTEDFL
KONI FRONT SHOCKS
Post by CIGARETTEDFL » Wed Jul 20, 2005 10:40 am
hi guys, wondering if anyone bracket racing with a stock style front suspension has tried using koni's spa1 front shocks?
I just bought a set and replaced my 3 way adj comp engineering shocks.
They sure seem soft on rebound compared to the 3 ways. and dosent seem like a lot of difference where they are adjusted. I havent ran down the track yet to test.
anyone have inputs on these koni's?
thanks
Dave :D
speedtalk
Site Admin
Site Admin
Post by speedtalk » Thu Jul 21, 2005 5:53 pm
I made the same switch a while back
http://projectautos.com/69-camaro/8-racing_project.html
On my car it wasn't even close - the Koni's were better everywhere, especially at letting the nose settle in high gear.
If the rebound is soft, just adjust them. All the way tight for me, and they are just about locked.
Maybe you meant compression? That I don't think adjusts. They do seem soft on compression, but that's where they shine in high gear.
Just my experience.
In Memory of Don Terrill
SpeedTalk Owner/Admin
CIGARETTEDFL
Post by CIGARETTEDFL » Thu Jul 21, 2005 7:50 pm
Thanks Don for the input, I have been having problems hooking as of late with the high temps. One thing I noticed when I took off the old 3 ways, that the left shock was very difficult to extend in the 90-10 setting. Hmmmm. anyway will try the konis out this weekend at US131, see if I can stand it on the back bumper.
Dave
CIGARETTEDFL
Post by CIGARETTEDFL » Mon Jul 25, 2005 2:43 pm
DON, ran the car this weekend with amazing results in consistancy. I love the weight transfer and settling down of the nose at half track. car ran 10.0569, 10.0569, 10.0547 with short times of 1.410, 1.410, 1.407
I couldnt be more impressed with those Koni shocks
speedtalk
Site Admin
Site Admin
Post by speedtalk » Mon Jul 25, 2005 4:31 pm
Can't beat that. I think there's two full turns of adjustment, where are yours set?
CIGARETTEDFL
Post by CIGARETTEDFL » Tue Jul 26, 2005 8:10 am
I have mine set, as a starting point, two full turns clockwise, which I belive is full soft on rebound.
speedtalk
Site Admin
Site Admin
Post by speedtalk » Tue Jul 26, 2005 11:15 am
I also have mine set at full loose - not sure which direction that is.
BillyShope
Post by BillyShope » Tue Jul 26, 2005 12:47 pm
To obtain more equal rear tire loading during launch with a RWD beam axle car, I would suggest that you adjust the right front shock to have a much higher shock coefficient (stiffer) in rebound (extension) than the left front shock. This allows the left front to rise "quicker" than the right front and provide cross-loading of the right rear, thus counteracting the effect of driveshaft torque.
CIGARETTEDFL
Post by CIGARETTEDFL » Tue Jul 26, 2005 1:43 pm
I would think you hit on a good point, however if the car is leaving straight would you still do that?
BillyShope
Post by BillyShope » Tue Jul 26, 2005 3:59 pm
Definitely! A car can "leave straight" and still be carrying a significant difference in rear tire loadings. And, the maximum performance from a tire pair is always achieved with equal tire loadings. Just ask the roundy-round racers.
speedtalk
Site Admin
Site Admin
Post by speedtalk » Tue Jul 26, 2005 6:08 pm
BillyShope wrote:A car can "leave straight" and still be carrying a significant difference in rear tire loadings.
I think that's right. I just haven't got that far in testing.
BillyShope
Post by BillyShope » Tue Jul 26, 2005 7:34 pm
I think you post at that "other" forum, Don, so you know what I'm going to suggest in the way of a test to "prove" that rear tire loading is equal during launch:
Pull, to the rear, on a horizontal chain that is attached centrally and at about the CG height, while the transmission is in Park, first, or reverse, and note the change in wheel loadings at wheel scales positioned under the front wheels. (Do not apply the brakes and do not place scales under the rear wheels.) If the load is removed equally from the left and right front tires, the weight transfer must then be going to the rear wheels equally. So, if you start out with equal rear tire loading, it will remain equal.
Unfortunately, this test is of absolutely no value when it comes to examining the effectiveness of the little shock absorber trick I proposed. It's only of value when it comes to determining how much preload you need or when checking out the effectiveness of rear suspension asymmetry or the use of a higher rate right front spring than left front.
(If you have done nothing to counteract driveshaft torque, more load will come off the left front than the right front.)
speedtalk
Site Admin
Site Admin
Post by speedtalk » Tue Jul 26, 2005 11:32 pm
This is really low tech, but I like to watch which way a car turns in the water box to determine preload needs.
katman
Post by katman » Wed Jul 27, 2005 1:15 pm
speedtalk wrote:This is really low tech, but I like to watch which way a car turns in the water box to determine preload needs.
Can you go into more detail, please?
Kevin A Thornton
KAT Automotive
For Speed Equipment, Nitrous Express
katman@everestkc.net
For AMSOIL products
http://www.lubedealer.com/kat
For Herbs from the Amazon
http://www.168336.amazonherb.net
speedtalk
Site Admin
Site Admin
Post by speedtalk » Wed Jul 27, 2005 5:12 pm
Standing behind a car during the burnout, if the rear goes left, odds are the front will go right off the starting line. In this case, more preload on the right may help.
