Hi Speed Timing Retard for today's heads?
73c34me
Post by 73c34me » Sun Mar 09, 2008 9:55 pm
Greetings. Hi speed timing retard used to be popular for some engine families. Is there a benefit of doing this for the typical 11:1 pump gas sbc with a modern off the shelf head? Assuming that total timing is 36-38 degress. thanx
bigjoe1
Show Guest
Show Guest
timing retard
Post by bigjoe1 » Sun Mar 09, 2008 11:05 pm
On the dyno, the engine always makes more horsepower with MORE total advance. When you retard it slightly, the torque picks up a few, and the HP goes down a few.
JOE SHERMAN RACING ENGINES
Ed-vancedEngines
Post by Ed-vancedEngines » Sun Mar 09, 2008 11:17 pm
More than you ever wanted to know about the MSD High Speed Retard. From the Retard who started the madness of it. lol
From the Horse's mouth. ;)
If you are running the engine as no nitrous but all motor, the high gear retard can definetly help.
When I developed that thing it was all analog using chips but it was not originally a nitrous retard. It was for the capabillity of keeping the engine at an ignition timing it was confortable with while pulling in high gear but allowed the car to be over advanced for launching in lower gers to give more low gear bottom end power. That probably doesn't make any sense of how running in an overadvanced condition can add power on the low end of the track but it does.
The basic concept of what we did was not begun by me. Old Stock Class racers using Point type Ignitions were using dual points and grounding out one set of points when they hit high gear with a remote switch in the car. WE just took their idea and ran with it to make it work with the MSD by using resistor chips to control the amount of resistance we were using to shunt to ground and that ended up taking the multiple trigger signals in the box and slowing down the amount of time in miliseconds it took for the triggers to reach the capacitors which we was using for stepping up the voltage like an additional power supply. Kind of like a car stereo amplifier does. That is how we got 12 volts to be high voltage.
Anyway. Yes' It can work very well and can increase your ET. That means helping it. You can also use the retard on a slick track with a remote switch. That was also a part of the original design.
Steve Masters took my original old fashioned old school Start/Run Retard that had been integrated into several of the different add on retards and made it better and made it to be Digital using transistors and included it into his Digital Boxes that almost everyone now is using.
When Steve first developed the Digital 6 it had far more energy output capality than was ever anticipated. It was better than the Pro Stock racing only MSD7AL2 that cost twice as much. Ouh oh. So that led to redevelopment and hopping up of the 7 series to give it even more energy which came out in the MSD 7AL3 boxes. Soon after the combination of what was sucessful in the Digital 6 was mated with the additional energy concept into the king of the ignition boxes, the Digital 7.
I have never been an employee with MSD so don't get the wrong idea. I just had some ideeas that MSD's Raul Konch (Moved on), Russel Stevens (Current National Sales Manager), Jeff Gaul (Deceased last year), and Joe Pando (Current Liason to NHRA-IHRA) worked out together by telephone and the mails, to end up with the finished product which Warren and I tested first protypes of. That was way back in the very early 1980's.
In a way my asociation then with MSD is kInd of like my piston ideas and designs that my piston company BRC Performance is making now for me. There are many products that I have gotten the mfg to altar for my desires, but I am by far not the only one they do this for. It is just recently that I was given any public credit for having any part in anything special in the industry. No money has ever come to me for anything. I just get stuff done the way I want it. Just like getting a cam cut to my specs. If you design your own workable cam profiles and pay for it to be made you can get it made. Comp Cams is now selling one I had them do for me several years ago. I don't always design my own. At times I use things already available depending on the budget.
You will enjoy the benefits of any the new Digital Boxes. Use the HVC Coil for the box and use a noise filter to protect the box. I strongly suggest using only the MSD 8.5 mm Plug wires too. The Digital 7 box will melt the end of the conductor of the best Holley Anihlator Plug Wires. Ask how I know. lol.
For a really strong MSD Box the MSD 10 is king and it is huge.
Ed
73c34me
Post by 73c34me » Tue Mar 11, 2008 7:27 am
thank you for your replies. good history lesson and reading.
In my 11:1 383 sbc w/ .043" quench I run 36* total timing. with the wide ratio muncie 4 sp. the 3-4 gear is hard to pick up rpms at the big end & thought retarding timing at this point might help..
YUDLOSE2
high speed timing retard
Post by YUDLOSE2 » Tue Mar 11, 2008 6:23 pm
Years ago we ran a 427 chevelle with a muncie wide ratio 4 speed. Our engine combo liked 42* timing in first thru third but didn't like it in fourth. I set up an old dual point to retard the timing and mounted a toggle switch on the shifter and switched it going into 4th gear. We picked up almost a tenth in ET and a solid 3 MPH. Cheapest 3mph I ever got. Try it it works!
bigjoe1
Show Guest
Show Guest
timing retard
Post by bigjoe1 » Tue Mar 11, 2008 7:50 pm
When I ran my old 1970 Chevelle ( MEAN GREEN) I had a 468 with 14 to one and a tunnelram-(815 HP) i ran 42-43 degrees, and if I retarded it 2 or 3 degrees, It would slow down .15 and one or two mph. NOT all combs will like the retard thing.
Ed-vancedEngines
Post by Ed-vancedEngines » Wed Mar 12, 2008 1:37 am
Joe,
If I am remembering right, we did not even have the High Gear Retard done when you were racing *Mean Green* .
Ed
jeffmckc
Post by jeffmckc » Wed Mar 12, 2008 12:31 pm
Before MSD, I had a 302 with a accel duel point, rewired to kill one set of points by a switch when it went into fourth, it was a lot of work for no gains. Good luck.
2007 HotRod Drag Week Winner SB/NA
2012 HotRod Drag Week Winner SS SB/NA
Fastest/Quickest Small Block N/A
Stock Suspension Car on Drag Week since 2007
9.67@ 139 with a 1.42 60' thru the Mufflers Dot tires
Thanks RFD Heads and Intakes
Big Speed
Post by Big Speed » Thu Mar 13, 2008 8:13 pm
For starters some people have got the dual point retard deal backwards,you run on one point at 31 degrees dwell on the launch ,then switch to the second point adding 3 or 4 degrees dwell, that retards timing, as far as high speed timing retard,study your dyno sheet,after peak torque the engine starts to richen up and after peak horsepower, the BSFC numbers show rich ,at somewhere after peak torque and right around peak horsepower add a 2-4 degrees of timing to burn off fuel. we have seen 10-12 horsepower gain on almost every engine
