Help me evaluate these photos. Chamber and Piston
A glance at the piston tops shows the first and third cylinders from the left showing a different and maybe better color/pattern. Any idea why these would burn differently? Firing order? Fuel distribution? Intake design? Random chance?
thnx, jack vines
thnx, jack vines
I agree Ron E. For every "bad" thing on the internet there is this type help. The internet is a beautiful thing when used properly.
I think my pullover problem had a bigger effect on things than I thought..
NO egt's on the dyno, why? I know better It was just a struggle to get everything adapted..
From the photos I see a line down each center cylinder the left one at 11 and the rt @ 5:30 at the head studs. Do you have the o rings around the plugs in the in port for the head stud? Do you have spring oilers? A friend of mine had a lot of trouble with an SB2 sucking the tank dry on the dry sump and the problem was the spring oilers spraying so much oil the scavenge couldn't keep up. We use 3933 in all of our aluminuim head stuff.
The lines are an illusion.. Yes it has the orings. No oilers.robert1 wrote:From the photos I see a line down each center cylinder the left one at 11 and the rt @ 5:30 at the head studs. Do you have the o rings around the plugs in the in port for the head stud? Do you have spring oilers? A friend of mine had a lot of trouble with an SB2 sucking the tank dry on the dry sump and the problem was the spring oilers spraying so much oil the scavenge couldn't keep up. We use 3933 in all of our aluminuim head stuff.
Off the subject a bit. I see what appears to be a black line on your plug to index it.
I was running an engine on my dyno one night and in the middle of a pass my customer leaned against the dyno room light switch turning it off. we saw sparks going to ground on every plug. turns out that a lot of black ink has carbon in it to make the color and conducts electricity.
Even though we couldn't hear the engine missing during a run simply cleaning the plugs off with carb cleaner gained 20 H.P. we now use another color and clean it off before installing the plug for the final time.Bill
Hendrens Racing Engines
1310 U.S.Hwy 221 North
Rutherfordton North Carolina 28139
828-286-0780
828-286-0780
WOW, that's interetsing. Remember the pullover thread? Anyway I spent a lot of time stalling this in the dark I was looking for anything and everything..Hendrens Racing Engines wrote:Off the subject a bit. I see what appears to be a black line on your plug to index it.
