That would be fine if the lift allows the pushrod to pass through the maxAlex W wrote:
arc point.
You need to account for the angle of the rod between the lifter seat and
the rocker seat. The PR is not moving in a linear fashion.
That makes perfect sence but you are still taking you lift measurments in a vertical direction. Whats the measurment between the center of your of your circle and the red dot. And the distance between the cicle center and the blue dot.Procision-Auto wrote:Alex,
Here is a scale drawing using two points on the arc (red & green), and a
a virtual point (blue) with a linear relation to the red dot.
Notice how much higher the blue dot would be if the rocker did not arc out:
I guess what Crane is trying to explain is that the relation between
primary side and secondary side of the rocker is not always 1:1 as
the cam lobe raises the valve.
I am not sure I follow you on that one? The drawing shows the rocker at three lifts- yellow(closed), red(mid-lift), green(open). The dotted lines are drawn from the shaft center line to the rollers contact point. It might be hard to see but the dimensions are showing the lengths of the dotted lines.MadBill wrote:But in this drawing, the valve lift per degree of arm rotation is proportional to the length of a line extended at right angles to the valve stem axis from the roller's contact point to the pivot, not proportional to the effective arm length from the pivot to the roller contact point... (In other words, the adjacent side of the right angle triangle formed, not the hypotenuse)
So what do you prefer Joe?bigjoe1 wrote:I think they got it backwards from what I would like to see. I never use them on anything.
JOE SHERMAN RACING ENGINES
That's all I've been worrying about. Mostly because the max lift rule classes I deal with. Minimal wasted motion and lift loss at the valve.xenginebuilder wrote:My personal preference is for a rocker to have the least amount of radical movement possible for a given "ratio" target, and make decisions about camshaft aggressiveness at the cam.
Understand first we're talking just of the effective motion of the valve end of the rocker. The pushrod end geometry operates semi-independently, based on the angles formed between the pushrod and that end of the rocker.Alex W wrote:I am not sure I follow you on that one? The drawing shows the rocker at three lifts- yellow(closed), red(mid-lift), green(open). The dotted lines are drawn from the shaft center line to the rollers contact point. It might be hard to see but the dimensions are showing the lengths of the dotted lines.MadBill wrote:But in this drawing, the valve lift per degree of arm rotation is proportional to the length of a line extended at right angles to the valve stem axis from the roller's contact point to the pivot, not proportional to the effective arm length from the pivot to the roller contact point... (In other words, the adjacent side of the right angle triangle formed, not the hypotenuse)
