CamKing wrote:You also have to have the required amount of time for the exhaust to pull on the intake during overlap. You can hurt the power by evacuating the cylinder too soon.
Speaking of 60's technology, ever noticed that duration @ the seat keeps shrinking and LSA keeps growing? Seems to be working in the exact opposite direction of the quoted theory, doesn't it?
We keep on gaining and gaining power little by little, and keep discovering and rediscovering that NONE of this power is from the exhaust "pulling" on the intake. Instead we keep making imrpovements by controlling reversion. This is especially true when your intake is restricted.
For an example, lets think about a Nextel cup plate engine. A big port with high vacuum could, in THEORY, certainly use all of the suction power you can offer, in order to start airflow earlier.
However, any one seen a Cup plate manifold? The fact that the "reversion control" baffles in the intake manifold make power prove that the exact opposite is occuring.
Common sense would tell you that, IF the exhaust is "pulling" on the intake, cutting back on overlap with a more aggressive cam would start airflow later, and, as result, show a LOSS in power.
To summarize, if we are gaining power by moving in the opposite direction of the "theory", why are we still using this theory.
If the results don't match the theory, adopt a new theory.
As far as 2BBL motors go, if your intake limits you to an RPM of 7500, there's really no point in trying to gain power at 8000 with a large exhaust lobe. If you can keep the exhaust valve shut longer and still evacuate the cylinder effectively, you gain power below peak HP, with no loss on the top.
