"You can get bad advice from SpeedTalk or good advice" and then he mentioned comments here by Big Joe and by Mr Harold, in a manner like he is calling thier words bad advice.
I hope my words here in this post straightens some of that up. I do not appreciate any of our dedicated loyal professionals to be talked against. Big Joe has likely built more engines and been written about than almost anyone in racing. UD Harold has probably designed and ground by now thousands of camshafts which many are still selling through big cam companies.
I now consider Big Joe Sherman one of my friends of Internet, Phone, and in knowing many of the same people. I have admired Big Joe or as I call him Mr Joe, for many many years, and still do. Yet I am not always in complete agreement with him. No biggee. No one agrees with anyone all the time. I hope. I consider Mr Joe or to you all Big Joe to be a valuable asset to SpeedTalk and we are blessed he is here with us.
Mr. Harold Brookshire, is one of the old time, all time Camshaft Greats. He is respected by most people in the camshaft industry. I also consider him a friend and at times, a professional business associate. MY first contact with Mr Harold was through Tim Allen who I used to buy all my Lunati through, and I wanted custom designed and ground cams, not off the shelf stuff always. He turned me on the Mr Harold and he did several cams for me that I liked very well while he was with Lunati. Mr Harold is one of the few men who has even now camshaft designs in catalogs in at least 3 and possibly 4 different big cam companies that are still selling cams he designed years ago. He knows the Cam business. Like Mr Joe, I also consider Mr Harold Brookshire to be a valuable asset to SpeedTalk and am happy he took my offer to come join with us here.
Quote: from Big Joe Sherman
Joe is mostly correct in this suggestion when it comes to racing engines. Joe is talking about peak power and average power. He is not talking about low end torque and spreading out the torque curve so someone can pull a stump outta the ground. He is talking racing. Plus the customer is talking about a little nitrous too. I am guessing that is where the customer is getting the idea of 112 LSA. Ooops. Original Poster, not customer. My bad.You have to be carefull, If the engine does not have high compressiobn ( 14 or 15 to one )the big lobe centers wont work.Pro stock engines have very high compression, ( 16 and higher) that is the reason it will work for them. On a low compression street type motor, wide lobe centers will give away lots of overall power .
JOE SHERMAN RACING ENGINES
No where yet in that thread is the original poster talking about this being a street car. I will say though that the 10.00- 1 compression is not the best ticket for anything performance related. You can still make one run with low compression as much as it is capable of though.
Now to the member talking about the guy whom you admire at Comp Cams, I am guessing you may have misunderstood him. If not he is wrong, I don't care who he is or how high up in his company he is.
Quote: from 540 Rat
Actually it was Billy Godbold of Comp Cams fame, who originally turned me on to the idea of choosing duration and overlap, then letting the LSA fall where it may. I fully agreed with him, and have since used and recommended that thinking myself. So, in the end, I guess maybe you are disagreeing with another Cam expert who knows a thing or two about cams also
Perhaps Big Joe or Mr Harold knows Mr Godbold and can ask him to join with the rest of us idiots here on SpeedTalk? I can not imagine a person with his position making an error in statement like that.
Here is the way I see some of what is in this discussion;
To begin with, A rough cam core from the heat treating but not finish ground is not a bar with round lobes to have as a starting place. There are lobes cast into the cam with defined LSA possibilities within parameters of the grind and how deep it goes into the heat treated surface. So to select the right core to grind, you need by then to have a pretty close idea of the LSA.
LSA is not just an accidental happening becuase of duration and overlap. Duration and overlap mean squat to what LSA the cam ends up with. The amount of LSA is derived from the Intake and the Exhaust Centers, that is where the exhuast lobe is at maximum right on the toe and where the intake is at maximum centered right on the toe. Or nose or you prefer. LSA is the position in a circle of degrees separating the lobes or as it is called Lobe Separation Angle. Any lobe design with any lobe profile can be moved to almost any LSA while the cam is in desigining. You can achieve the same LSA with many different cam designs and many different opening and closing positions but the relationship between max intake lift and max exhaust must stay the same for the LSA to stay the same.
Please bear in mind, I am talking about hypotheticals that can be ground on a cam. not what can make the most power. I am talking about what is physically possible. There is no way to let the LSA simply fall where it wants to be, becuase it is only a byproduct of the grind design. It is not. It is only a byproduct of Angles of separation between max intake and max exhaust lift.
Now the grind or overall lobe profile with durations, ramps intensities with LSA does determine the amount in degrees of overlap. Keeping all lobes the same but separating them further will decrease the degrees of overlap, all things equal. Likewise shortening or bringing the lobe separation angles of intake and exhaust closer together, all things equal, will increase the degrees of overlap.
Decreasing overlap with wider LSA will give a smoother idle, increased manifold vacuum, better drivability with a sacrifice of peak power and average power but will hve a lower but more broad torque curve, so it is preferred by the OEM for street driven vehicles. It is also many times preferreed by engine builders like myself when building daily street drivers in heavy cars or trucks. That way I can build in a lot of duration with strong lobe profile but have manageable street manners, in higher compression street driven vehicles. I do this quite a lot with hydraulic roller cam engines. We are talking drivability, not whatever it takes to get maximum performance when we do this though. Actually when Harold was at Lunati we together cooked up a few of these off the wall street hydraulics for my customers.
Back to the person asking his original question;
Why 10.00-1 compression in this kind of engine? Your compression is holding you back from being able to more effectively use a cam that would do you better. With 10.00-1 compression statis and the overlap a big racing cam will have your actual running compression or what is called dynamic compression will be very low.
Quote: from 1320 racer & from Bad95GTs
Quote from Bad95GTsWould you post a couple of examples of the whole threads you have received bad advice here from?
Please read all of the above.There is good and bad advice here on Speedtalk.
For one saying 114 lobe separation will not work with 11 to 1 compression.
This has nothing to do with anything.
Valve opening and closing events are what is important.
Lobe separation is an end result.
No one who knows anything picks the lobe separation first and then designs the cam around that number?
The original poster asked the question wrong for what he wanted to know. He got not bad advise. [Ed]Quote:
Is there a limit to head flow??
I guess literally there is.
You would not want a pro stock head a 2.0 liter engine.
Most heads on a typical engine are no where near big enough resulting in an inefficient cam design.
Part of your statement is bad advice though.
Quite incorrect. Why? Becuase I says so. lol.Quote:
Fact is in most amateur racing engines the cylinder head runners and measured on the bench CFM are too large for what the overall engine needs and the vehicle needs for the application.
Not for sure at all what you are meaning about insufficient cam designs. The reason many engines have a cam design that is not well matched to their combination is becuase they shop in a book to pick out their camshaft from existing designs, not really fully understanding just what the numbers they see can represent and usually foloowing the advice of a buddy or a cam advisor who will design you the perfect cam for your needs in 5 minutes or a little longer.
We here at SpeedTalk pride ourselves in being a vehicle of good information for our many members and guests. However who is to say just what is good advice and what is bad advice? Shall I be the judge of which advice posted is bad or good solely based on my opinions? I think not. To put is a different way here. For example if I were to ever publicly post exact details of how I set up cylinder heads for serious high rpm high horsepowered applications, the majority of readers, members, and even other engine builders would see my words as bad advice, becuase it goes against what is accepted and is widely done by most everyone. Yet it works great for me. Another example; I very good friend of mine and a good engine builder and I have butted heads for years about building and design techniques for a nitrous engine. In his words and in the opinions of many, I am doing it all wrong. Recently that person told me I had been right and he now was doing what I been telling him to do and it works better with more power. When he was not accepting the info I told him, to him it was bad advice. Now he is on the band wagon and doing it similar to me. So just maby at times what we think is bad advice just may not be. We allow a mix-mash of differening ideas and opions here so the reader can read and see more what can better fit their needs. At least we try.
Ed
