boost vs. compression revisited...
what has been the norm for compression ratio with blown non-intercooled applications with C16 fuel? I know it depends on what type of head is used, but there still must be a roundabout number that works the best. I know with inter/aftercooled blown motors up to and maybe beyond 11.0 compression works well, but what about with no cooler? Can extra rich air/fuel ratios allow for higher compression ratios? I have my own experiences with these combos but am wondering what other people have tried. Any thoughts or experiences here would be appreciated...
As you suggest, head design and combustion chamber shape play a big role in establishing how much effective compression the engine can tolerate. The formula for determining effective compression ratios is as follows:
ECR=(14.7+Boost in psi/14.7)*Static CR
Altitude, fuel delivery and ignition also play a role in determining maximum ECR. For non-intercooled applications running C16, I would think a 8:1 to 9:1 static CR would be appropriate. Anything more than this would limit boost; anything less than this would compromise low-end performance.
"Can extra rich air/fuel ratios allow for higher compression ratios?"
There wouldn't be any point to doing that if your trying to make power with gas. You'd be better off, power wise, to lower the cr and up the boost. If your trying to run with a higher cr you might want to take a look at VP's "Import" grade of gas. It's by far the best one for blower applications (3-5% power increase over C16 or NO2), but it's also twice the price. Water injection would be another way to squeeze a little more out of that type of combination.
I agree with Steve, 8 to 9 to 1 is generally the area for gas applications. With 8 to 1 or lower for the higher end boost and power.
At 9 to 1 cr and 20 psi your looking at a little over 21 to 1 effective cr which is pushing C16. Of course there are some varying factors that can make it work.
That's my thought's and experience anyway.
Creekside Racing Ministry
John 14:6
Ron Clevenger
CSU Gas Dominator ProCharger nonintercooled
Top Eliminator West http://www.topeliminatorwest.net
Steve Morris http://www.stevemorrisengines.com
6.49@219mph (still tunning)
John 14:6
Ron Clevenger
- New Member
Go with the lower CR and boost it.
I would also find a way to get some sort of intercooler on it.
In the past I was able to make almost 4hp per cubic inch in a V-6 drag engine with 9.1 CR and 28lbs with one turbo. It wasn't a bomb either.
Turbos are a bunch of fun!
If you always do what you have always done,you will always get what you always got.
- New Member
For tech comparison go to VP's website and click on there "fuel spec sheets". Compare the "Import" to C16 and NO2 which would be best second choices. The "Import" is designed to be used with high mechanical heat induction. The distillation evaporation percentages are much more favorable for your application. If the rules allow it.....that is. Be prepaired to pay around $16.50 @ gallon in 54 gallon drum quantities. The "Import" will make 3 to 5% more power than the C16 or NO2.
Happy racing...........
John 14:6
Ron Clevenger
John 14:6
Ron Clevenger
