old prostock head? #22530959 DRCE 1
FullThrottleBill
Post by FullThrottleBill » Thu Dec 27, 2007 4:49 pm
I've seen this listing in the GMPP book forever, but there is no tech info at all. Anybody have the specs. for this one?
Thanks in advance,
Bill
cboggs
Post by cboggs » Thu Dec 27, 2007 10:21 pm
Bill,
What kind of "specs" are you looking for?
it's basically a raw casting, no bolt holes, no guide holes, .. etc.
kinda like this, .. http://www.raceflowdevelopment.com/cubing.html
Curtis
Race Flow Development
FullThrottleBill
Post by FullThrottleBill » Fri Dec 28, 2007 8:30 am
Curtis,
Is this head one of the old 4.840 BS or 4.900 BS?
What are the possibilities for chamber CC and valve angles?
What size (CC) are the as cast ports?
Will they work with standard lifter locations and cams?
Thanks,
Bill
Ed-vancedEngines
Post by Ed-vancedEngines » Fri Dec 28, 2007 10:05 am
I am not Curtis or any cylinder head ghru but I think that those originally are for the standard 4.840 bore spacing. These guys though are doing strange things with DRCE I heads.
After being machined and modified by someone like Curtis or Darin or other Good Cylinder Head guys those things can make for unreal power potential.
Ed
cboggs
Post by cboggs » Fri Dec 28, 2007 10:26 pm
Bill,
The DRCE 1 casting was the best of the bunch I think, ..
It was originally 4.84" bore space but the casting was made thick
enough it's now used to make 5" bore space heads.
Some Pro stock teams still use this casting over the DRCE 2, ..
of course most are trying to use a rather weak DRCE 3 casting now.
It's a raw casting, valve spacing, chamber size etc are up to the
cylinder head person building the head. CC of the as cast ports,
um, .. there really isn't any, .. it's left very small so the port designer
can move the port where ever he/she wants.
They need specific lifter locations and cam designed for them.
Curtis
FullThrottleBill
Post by FullThrottleBill » Sat Dec 29, 2007 1:11 pm
Thanks Curtis,
That's what I needed to know.
cboggs
Post by cboggs » Sat Dec 29, 2007 1:36 pm
FullThrottleBill wrote:Thanks Curtis,
You can call me at the shop if you need some help with this stuff, ..
703-339-1039
M-F 10 am to 6pm
Curtis
