WAWA wrote:What about reversion and narrow LCA cams? My experience with EFI showed there was a limit to how far you could go with the two.
I couldn't go over a duration of 225 @ .050 or any narrow that 114 LCA before the motor 302 ford would burp and fart. This was an 88 mustang. I even switched to mass air system didn't help. The cam was to wild.
A carb doesn't care, changing optimum cam timimg to make a computer happy is expensive and illogical.
I'm sure EFI has progressed alot further, but I'll take a carb anytime thank you very much.
WAWA wrote:No doubt fuel injection has evolved. I will point out an example.
a buddy of mine has an 89 mustang with a stroked facorty 302 block to
331 c.i. (cant remember exactly) has gt40 heads and intake, approx 9.8:1 compression., naturally aspirated.
The problem is the engine builder I feel played it safe by using ford B303 cam only due to playing it safe with the ECM.
I'm going on memory but that cam spec'd @ 225 @ .050 114 LCA
Now imagine what if compression was bumped up 1 point and another 25 degress in the cam switch to solid, single plain intake, and match it up with a proper sized carb. I'm guessing 60 hp easy. Thoughts anyone?
Troy Patterson wrote:Fuel injection? It's the Titanic sailing forward at full speed in the North Atlantic!
Troy Patterson TMPCarbs.net TMP Carbs
Users browsing this forum: 67 'bird, Brad_AUS, Google [Bot], PhilD and 6 guests
