help find 40% leak,heads or rings?
blownzoom440
Post by blownzoom440 »
what is the best way to find the leakage.the hone looks ok,no signs of detination on the piston top,poured gas in the port and barely leaked any. i have pictures here. http://drr.infopop.cc/eve/ubb.x/a/tpc/f ... /218107839 thanks for any help!
"69"satellite,3900lbs,8-71,edel victor heads,I/C,446cu.in W/gas 1250 carbs
blownzoom440
leak check
i leaked the block n head seperate,8% on the block and 10% on the head from the exhaust valve.i will get the heads done and assemble with a new cam with 113 lobe seperation.thanks anyways!
