and if matter is utterly destroyed,you should have some serious residual energy (heat) there...think of anti-matter + matter = Huge bang. It basically cracks physics open...Larry Morgan Jr. wrote:Off topic a bit, but crazy things have happened when things get near absolute zero. We have 5 known states of matter now because of it. The one near absolute zero being the Bose-Einstein Condensate. In a few experiments with thing in the nanokelvin range, atoms have imploded together and "disappeared"
And nobody knows for sure what happens at exactly absolute zero... If you use modern equations and quantum theory, since matter is made of energy, you lose all energy. So, the matter ceases to exist, which goes against the law of conservation of energy...
Where does power come from?
-Bjørn
"Impossible? Nah...just needs more development time"
If you create a matter/anti-matter explosion,and the chamber can hold it, wouldn't you compress atoms to the point of infinite density, which in turn means infinite gravity(ie a black hole)? Assuming that the chamber can still handle the forces, just think of the chamber filling thats going to happen when the intake valve opens! Now thats a pressure drop! ( sorry guys, I couldn't help throwing that one out there.)
as far as optimum fuel/ air ratio, have you ever considered using CO feedback? My understanding is it's way better than excess O2. If you could tune for 200 to 300ppm it would be about perfect.
I think the sensor technology is not available and that may be why you see Excess O2 used as a closed loop feedback.
just my thoughts.
just my thoughts.
Paul
Adv Et Dragracer
Adv Et Dragracer
TMP Carbs Troy Patterson
automotive breath wrote:It's not only about fuel atomization, although that can be big part. Check out this CFD showing flow vectors and equivalence ratios to highlight in cylinder mixing of the fresh charge with residual gas.
"...this means that generally in the cylinder there will be fuel richer regions with lower temperature and leaner regions with higher temperature...."
"...the effect of mixing in the cylinder is very important since it controls the local temperature and composition in the cylinder. There is a correlation between local equivalence ratio and residual gas fraction with temperature. The assumption of homogeneous composition (in the cylinder) could be quite inaccurate even under premixed conditions in the intake port..."
http://me.engin.umich.edu/autolab/Publi ... 002_05.PDF
Alternative Fuel?
Nitrogen allows us to convert the heat of the combustion process into an energy form we can use to due work, i.e., press the piston down.
Troy Patterson TMPCarbs.net TMP Carbs
You'd need a hefty bench to flowtest that one...2dumb2kwit wrote:If you create a matter/anti-matter explosion,and the chamber can hold it, wouldn't you compress atoms to the point of infinite density, which in turn means infinite gravity(ie a black hole)? Assuming that the chamber can still handle the forces, just think of the chamber filling thats going to happen when the intake valve opens! Now thats a pressure drop! ( sorry guys, I couldn't help throwing that one out there.)
And,the seated pressure of the valvesprings
-Bjørn
- tommurphy73
Re: Where does power come from?
This may be off topic but I would have thought that the highest temperature produced would be for a fuel air mix which was at Stoichiometric ratios about 14.7 to 1. Any mixture above or below this would produce less heat. At ratios greater than 14.7 to 1 the mixture would burn slower and for longer transferring more heat into the piston and cylinder head making the temperature appear higher. At ratios below 14.7 to 1 the mixture would also burn slower but since there is more fuel to vaporize this would reduce the overall heat produced.automotive breath wrote:"...this means that generally in the cylinder there will be fuel richer regions with lower temperature and leaner regions with higher temperature...."
The interesting thing here is why does a ratio of around 12 to 1 produce the most power?
Regards
Tom
- af2
Slower burn could be a complete burn at a given time. No detonation!tommurphy73 wrote:This may be off topic but I would have thought that the highest temperature produced would be for a fuel air mix which was at Stoichiometric ratios about 14.7 to 1. Any mixture above or below this would produce less heat. At ratios greater than 14.7 to 1 the mixture would burn slower and for longer transferring more heat into the piston and cylinder head making the temperature appear higher. At ratios below 14.7 to 1 the mixture would also burn slower but since there is more fuel to vaporize this would reduce the overall heat produced.
the most power?
Regards
Tom
GURU is only a name.
The ratio of 12 to 1 created the best power because of the molecular proximity (density of hydrocarbon atoms) which made things easier for the ignition to comence under mixture and pressure.The interesting thing here is why does a ratio of around 12 to 1 produce the most power?
Now days with the higher energy and multilple spark it might not be the norm it used to be especially in the more thermally efficent power plants.
regards
14.7:1 does not produce the most heat, a slightly leaner a/f ratio produces the most heat.
A slower burning combustion process doesn't necessarily put more heat into the piston / chamber - although it might, but it is likely to heat the engine more, even causing overheating as a result of the continued burning on it's way out the exhaust port.
"Molecular proximity"! This is a key! I've been very busy and haven't had the chance to really delve into this much for a while.racing97 wrote:The ratio of 12 to 1 created the best power because of the molecular proximity (density of hydrocarbon atoms) which made things easier for the ignition to comence under mixture and pressure.
regards
Molecular proximity is a critical component in increasing the effectiveness of a "nitrogen heater / exciter," more widely known as an internal combustion engine.
Last edited by Troy Patterson on Sat Oct 06, 2007 12:33 pm, edited 1 time in total.
Flame temperature will vary with engine design and running conditions among other variables. The transfer of this heat to the engine depends on component material of construction and time.
approximated flame temperatures:
air:fuel | E ratio | flame temp.
12:1 | 1.25 | 1976
13:1 | 1.15 | 2055
14:1 | 1.07 | 2114
15:1 | 1.00 | 2122
16:1 | 0.94 | 2071
17:1 | 0.88 | 1996
18:1 | 0.83 | 1926
12:1 | 1.25 | 1976
13:1 | 1.15 | 2055
14:1 | 1.07 | 2114
15:1 | 1.00 | 2122
16:1 | 0.94 | 2071
17:1 | 0.88 | 1996
18:1 | 0.83 | 1926
- tommurphy73
