Well, here's some food for thought.
Now I ain't no engineer and make no claims, but-
Look at radial flow turbine (such as a turbocharger) design and math.
Empirical and theoretical data says as the gas flow goes from the nozzle area and spirals inward to the scroll outlet at the turbine blade tips, velocity AND pressure go up within this continually narrowing channel.
But, you are dealing with a compressible fluid, not an uncompressible fluid. So, do the physical properties of the fluid make a difference? It would appear so to the layman that ain't never had the laws pounded into him.
Port flow between floor and roof?
Holy Crap -
if you ain't reading this whole page ............
http://www.aeronautics.ws/blunders.html
Function - the hidden math.
http://www.pontiacengines.com
matter of definitions
Its not that air is incompressible, its an engineering convention that simplifies calculations.
At low air speeds (low mach numbers) you can treat air as if it were incompressable for some types of calculations and the errors due to that simplifying assumption are so small that they can be ignored.
At higher mach numbers they have to go through all the complex calculations to account for these errors.
http://galileo.phys.virginia.edu/classe ... node6.html
As you can see by the above link, air flow in a port at sonic choke or even .55 mach would have to be treated with consideration of compressability effects, so not a simple calculation for things like computer simulations.
Larry
Larry
