dome piston with a Vortec head
Larry Woodfin
Postby Larry Woodfin » Sat Jul 21, 2007 5:33 pm
I really like the small block Chevy Vortec head [original factory castings 062 or 906] and have built several strong running bracket race engines using them. They are expecially suited for mild, auto trans combos because of a broad power curve.
So far, I have only built flat top, flat tapppet, 355 - 360 combos. I usually flat mill the heads about .040 and that usually gives about a 60cc - 61cc chamber.
My question, have any of you experimented with a small dome piston using the Vortec head? Due to the spark plug location I "think" the dome would need to be a simple "bar type dome" down the piston center.
Any experience or comments. Just looking for some added compression, maybe add a point of compression.
Thanks
Larry Woodfin
automotive breath
Postby automotive breath » Sat Jul 21, 2007 6:54 pm
Larry,
I have done a few engines with the Vortec heads, all flat tops. Nice port design.
I *think* these pistons would work. I use them with topline/RHS heads.
These are inexpensive forged pistons from Keith Black for 350 w/5.7 rod;
part number KB727. They do make these for other bore, stroke, rod
length combinations.
Larry Woodfin
Postby Larry Woodfin » Sat Jul 21, 2007 7:47 pm
Breath,
Thanks, looks just like what I need to clear the spark plug boss. A few mins spent rounding the edges would have those ready to go.
Larry Woodfin
automotive breath
Postby automotive breath » Sat Jul 21, 2007 8:19 pm
Another thing I have done is to take the old 1/8" dome TRW pistons and mill
the dome where needed to provide clearance. The domes are solid so milling
doesn't do any harm. The TRW's weigh a ton but can take a beating.
Larry Woodfin
Postby Larry Woodfin » Sat Jul 21, 2007 8:56 pm
Breath
check your PM
Larry Woodfin
Return to “Engine Tech”
Who is online
Users browsing this forum: amcenthusiast, Bing [Bot], ChrisL66, Cogburn, jcisworthy, lbs-ft, MadBill, woodaca3680, Yahoo [Bot] and 40 guests
