Cam design basics ?
CamKing
Re: Cam design basics ?
Post by CamKing » Wed Jul 24, 2013 10:25 am
ptuomov wrote:CamKing -- Thanks a lot, that's very useful and detailed info. Do I understand correctly M product code means mechanical? Would these run well on a hydraulic lifter? Would the H74500Ex that you listed in your Cayenne DP (Diesel Power?) cam post work, it looks similar to that profile? Or am I just assuming untrue things about your product coding system?
Sorry, that should be an 'H74500EX", not "M74500EX", and it is a Hydraulic lifter profile.
And MadBill was right, the DP is for Daytona Prototype, and Porsche did not like getting beat by their own engine.
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
ptuomov
Post by ptuomov » Fri Jul 26, 2013 3:10 pm
Interesting. Do you happen to remember what the base circle diameter is for those Porsche Cayenne cams? Also, could those profiles be run on a 35mm hydraulic tappet?
greg
Post by greg » Fri Jul 26, 2013 5:56 pm
op
the isky catalog does a good job in explaining stuff... :)
ptuomov
Post by ptuomov » Fri Jul 26, 2013 9:45 pm
Ok so Boxter and Cayanne have 33mm lifters so these should fit on a 35mm lifter just fine.
CamKing
Post by CamKing » Mon Jul 29, 2013 11:47 am
ptuomov wrote:Interesting. Do you happen to remember what the base circle diameter is for those Porsche Cayenne cams? Also, could those profiles be run on a 35mm hydraulic tappet?
Yes, they'll work on a 35mm hyd tappet.
Base Circle on the Cayenne cams was 1.440"
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
