Ed-vancedEngines wrote:Ok guys,
This can be a littloe sticky, becuase all engine combinations and components are not shaped the same or made the same or assembled the same with the smae exact combinations.
What a bunch of worthless words. lol.
Some engines can better benefit from more enhanced quench/squich charastics than others need. Joe is correct that a .051 quench will still be plenty for what most of us will see any benefit from. I have seen benefits in certain combinations using a very tight quench and no benefit in other combinations doing the same thing.
In the listed combination in discusssion, I see no benefit to a severely tight quench at all. The disadvantages are piston hitting head and you lose head gasket seal or damage parts. . I do know for a fact that an exact accurately measured quench with a BB Chevy and big dome TRW Pistons will result in piston coliding with head at upper rpms when set-up at a .028 quench. IT will not work. .040 to .051 would be much better.
Maybe some of us do in certain applications with certain combinations do set things up for a very tight quench. WE who do have learned the hard way about what we can and can not do by over-pushing the limits. We know the limits becuase we learned the limits in an expensive learning process. All most of you should be doing is learning from our learning experiences and you not repeat those catastrophes we experienced in our learning curves.
For what it is worth, Mr Joe Sherman owned and drove the first barely streetable heavy Chevelle with a 468 cu in BB Chevy into the 9 second range in a 1970 Chevelle. Calculate the power needed to do that and know that he did that with old school heads and parts. So he does know several things about getting the 454 to run.
Ed
Hmmm, .028 will not work, you say. Geez as I said above, a buddy of mine runs his 540 at .028 quench and the pistons just ever so barely kiss the heads, but no noise from it, so it is just exactly there. And he turns 7,000 plus rpm and runs 9.90 at 141 with no issue, for I guess a couple of years or so now. He also is a member of this forum. I won't give out his name, he can do that if he cares too. Maybe he'll chime in on this
Ed-vancedEngines wrote:Hmmm, .028 will not work, you say. Geez as I said above, a buddy of mine runs his 540 at .028 quench and the pistons just ever so barely kiss the heads, but no noise from it, so it is just exactly there. And he turns 7,000 plus rpm and runs 9.90 at 141 with no issue, for I guess a couple of years or so now. He also is a member of this forum. I won't give out his name, he can do that if he cares too. Maybe he'll chime in on this
Those words were written for the purpose of being instructional not confrontational.
Perhaps two people are not measuring dech ht the same. Perhaps two people are dealing with a different amount of piston rock. Perhaps two people are dealing with different weight pistons. Bottom line is I strongly suggest to not do it, and in your post by your words you are saying that his is showing marks of piston contact. In his examples you are saying he ran in excess of 7,000 rpm, amd in my example I was running in excess of 8,000 rpm. So it looks to me that we are both saying the same thing here.
Before Fel-Pro came on the scene we used the factory recommended head gaskets made for Gm by Victor. They were red in color and had two little holes punched in a certain palce on them to distinguish them from the other Vistor gaskets made for OEM & replacemet. The part number was VictorCore 3868VC. IT had a compressed thickness of .038 and In that engine to begin with I had an accurate deck ht of .010 out of the hole. Do the math.![]()
Now when I say accurate deck ht, I mean accurate. Back in those days we wasted too much time in making the deck ht to be exact with each other, the head chamber cc to be exact, the blocks to be honed with 180 degree water running through them as they were honed, and a lot of other useless tricks we all went away from. Accurate deck ht was achieved by measuring the piston on each side and intentionally making it taller than wanted so we could then accurateloy mill down the piston top to achieve our perfect combinations of perfect deck ht and perfect chambers to give us perfect engines.It was mostloy all wasted time, for the good it did. lol
Ed
Ed-vancedEngines wrote:Ok guys you have drwn me back into this, but not to argue. I refuse to argue. Yes' I do read most if not all of the posts on this board or I try to. As one of the moderators it is also part my responsibility to keep the forum clean and git rid of the trash and to keep sure things go as they should on a professional board.
All of that said, I will do my best to come back tonight and hopefully be more descriptive of how something can work ok for your friend and not have worked well for me. I would love to know who the engine builder in Texas is you are talking about. I do know many of them and also their building traits. I can only think of but 5 including myself that like a tight quench and one of them does not do it with but his own personal engines.
It also looks like we picked up a new face using the nick of 540. That is ok too. We are all in this hot rod jungle together.
I call it collective criticism and it is good! You have to read a couple of times to see what they said but when you realize it it is good!
See ya later tonight I hope.
Ed
af2 wrote::D 540 every thing you said was from my motor, as in yours. Would you build the exact same motor for a customer is my question??
That is what I feel is the real question and not what you can get away with it's you're motor but what the average one will race day to day and can't check things that a builder will do and usually make them mad saying the clearance is too tight we have to address that!!
I am trying to give the difference between an owner builder and a builder non owner sense on things.
Why the name change!
540 RAT wrote:af2 wrote::D 540 every thing you said was from my motor, as in yours. Would you build the exact same motor for a customer is my question??
I guess at this point I should clear something up. I am 540 RAT from Southern California. My buddy Jim, from Texas, with the .028 quench 540, is 540HOTROD, two different people, not a name change.
Users browsing this forum: bassettmustang, BlitzA64, Boz-Race Engines, Brian S, Ericnova, frankthetank, Google [Bot], olds80Six, sam-missle and 13 guests
