anyone have any experience with this program??
i have a flow sheet from a customer who had their heads tested on a bench supported with this program and the D/C numbers and "potential flow" numbers seem off.
is this just a case of programming "GI-GO", or are there some problems with the program?
WinFlow program
Dwayne,
I don't use the Superflow software, .. I use the portflow software,
1,000 times better I think.
But, in both software packages there's important info that if not
entered correctly will throw those D/C number way off.
Was that the flow chart some one posted on Moparts??
Curtis
Curtis
Race Flow Development
no, its a B1BA head that someone sent me for freshening, and they included the flow sheet from when it was ported.cboggs wrote: But, in both software packages there's important info that if not
Curtis
the D/C numbers look like they are all based on the same peak value, meaning, they are way low at the low lifts, then rise throughout the lift curve.
its as if all the D/C calculations are based on the window for about .700 lift.
also, on the exhaust side it shows the high lift flow as 120% of the potential flow.
