Strange Magic wrote:
As BTR said, you do as much as you can do regardless of the weather you have a power adder or not.
This is actually what BTR wrote and it does not say that.
But it is not surprising you have chimed in to defend him. You two are very close friends correct?
Don't worry about making the exhaust side better. You will be fine the way it is. You don't need to worry about the exhaust port flow on a nitrous motor on any of these good flowing cylinder heads. It is controlled by the camshaft.
I am sure most people would disagree with my findings, but many follow everyone else like sheep and don't think for themselves or really think about what is really going on during each cycle.
This site is not about mindless sheep. It has many great minds with years of experience.To dano73327:
BTR wrote: I got my information from the internet and books. I never raced or built a nitrous engine in my life. BTW just about any engine will pick up whether using nitrous or not from the described modification. I read that too.
Another fine quip! Why this tone?
And yet another……BTR wrote: My opinion differs from you guys and most other people. If I didn't go fast with my customers stuff and my stuff, I would consider myself a jackoff.
Joe Mendelis wrote:
Have you ever built an engine and run pressure transducers in the heads? I have seen enormous gains on the exhaust side on an SB2 head that only picked up 7 cfm. 40hp and -2 degrees of ig. timing. How could that not make a big difference on a nitrous engine?
Why can gains be had with ig. timing on the exhaust side? And why wouldn't that help a nitrous engine? Do you want to run more timing?
What are you doing on your exhaust port? What is the valve size, venturi size, exit size, and valvejob. Maybe you arent seeing any gains because flow numbers look good. There's alot more to look at. Exhaust is very picky about certain things.
Curtis wrote: I've been reading this thread since it started, .. interesting to say
the least.
I've worked on NOS engines since the 80's and days of working at Sonny's
and the first 200 mph door car, .. . a better exhaust port has
ALWAYS made more power.
Would not a civil response to these gentleman lend to the conversation?
Please do us all a favor and keep these condescending remarks on the ROP site
www.realoldspower.com
It is just that language which is used there that has filled that forum with discontent.
This forum is far too respectable to have such discourse.
