Trying to find a Honda application tensioner bearing- NAPA crossed it to a SKF 6203-2RST but this new bearing is thinner.
existing bearing dimensions:
OD 40mm
ID 17mm
thickness 14mm
markings:
13-256
F-130000.43/R844
K*T*308A
INA
Thanks
tensioner bearing cross over
Re: tensioner bearing cross over
Most times its just easier to get the complete pulley/tensioner rather then try to just change a bearing.
If I have a customer request for that I don't waste the time as from what I have seen some bearings
are of lesser quality then the OEM used to start with.
- Caprimaniac
Its a INA- bearing, so contact the INA supplier in Your country?''
ProPower is right, and most of the times you get upset by paying 100$ for a assembled part instead of the 25$ for the bearing. Have done so plenty of times, even if I have stacks of bearings in the basement- very seldom the one I need right then; but sometimes I'm Lucky...
I did purchase a replacement assembly- Honda part with Gates name on it. Thought was to have a spare.
You can search bearing suppliers by size to find one with the size you need. Found a NTN Radial BB 40mm OD x 17mm ID x 14.28mm thick
NTN #87503 or NTN #WC87503
I found those by cross referencing size at https://www.motionindustries.com/taxono ... /browse/en
You can try searching through only INA(Schaeffler) bearings, also.
https://www.motionindustries.com/produc ... onomy=true
You must be putting a lot of miles on that Accord.
The opposite actually. 40k km 2015
minor noise started coming from belt area- tensioners are hard for me to diagnose as they are dynamic. Wasn't the tensioner as I replaced the pulley and wrecked this bearing afterwards. Noise still there- will have to wait until it becomes really annoying.
bearing would be 17x40x17 double ball bearing. Emailed INA rep here- $50cdn.
https://www.youtube.com/watch?v=ZkjPzm-Qlgo Sound like this?
https://www.google.com/search?q=2013+ho ... e&ie=UTF-8
5203-2NSL Nachi Angular Contact 17x40x17.5 17mm/40mm/17.5mm Double Ball Bearings
