Spring retainer OD way smaller than spring OD?
Re: Spring retainer OD way smaller than spring OD?
I dont know if .020 is too loose, but a lot of springs I've had have between .010 and .020.. I suppose if the 1st step is OK and the inner touches the outer you only need to concern yourself mostly with the clearance on the outer spring...
