100% 'spirited' street car. Transmission: stock convertor auto+OD - 3.55:1 gear.
Converted the lifters to solids.
CompCams XE256H
Adv.Dur. - Int 256° - Exh 268°
Dur. 050 - Int 212° - Exh 218°
Lobe lift: Int 0.298" - Exh 0.303"
Valve lift @ 1.5:1 ratio: Int 0.447" - Exh 0.455"
Valve lift @ 1.6:1 ratio: Int 0.476" - Exh 0.485"
Lobe Sep: 110° - Int Cent: 106°
Valve timing: Int 22°- 54° - Exh 20° - 68°
Now I ended up with a reground retrofit hydr. roller recently for another (318ci) engine.
Supposedly reground to following specs:
HR-279-MSBS-360
Adv.Dur. - Int 258° - Exh 264°
Dur. 050 - Int 206° - Exh 212°
Lobe Lift: Int 0.320" - Exh 0.325"
Valve Lift @ 1.6:1 ratio: In. .512" - Ex. .520"
Lobe Sep: 112°
---* RV and tow applications
* Good low-end
* 8:1+ compression, intake, headers, gears (for better performance)
* Stock stall
* Noticeable idle
Started wondering how these two cams would compare, and maybe if/how much the roller would be an improvement in the 360ci over the flat tappet cam?
