Thanks Melway,
I PM'd you a few inside pictures
I totally agree that modifying the top of this wonderful manifold would not be ideal as it is definitely configured for a single carb or throttle body.cjperformance wrote: ↑Wed Jun 05, 2019 7:24 pm Look at how each runner pulls from the traditional style open/single/square plenum. Its hard enough to control how each runner pulls from a fairly uniform shape plenum. When you make the plenum longer you now have put the 4 outer runners up at the ends of a plenum and the 4 inners are right in a big open space. This messes fuel distribution up even more. You can fix this by pulling the ends of the plenum out further , moving the 4 inner runners out a little 2 toward the front and 2 toward the rear and reduce the inner plenum area so the plenum is not too big, you then need to bring the runners up higher to clear engine components due to the longer 'moved out' plenum setup,,, ah now that sounds like a tunnel ram!
Stretching the plenum out will straighten the runner and port alignment but wont help distribution at all. This has been tried before, if it was the cure we would all be running dual downdraft webers in line, an inline 4 barrel or 2 sideways 2 barrels inline. A long thin plenum does not help and for 2 conventionally mounted 2 barrels (aka stretched 4 barrel) a longer full/traditional width plenum does not help.
Being we are talking 90* V8 crank then the firing patterns we have to use also throw in runners that draw right next to each other, that's easier to control in a uniform plenum arrangement.
180* crank, whole different ballgame.
Scott,Scott wrote: ↑Sat Jun 01, 2019 1:09 am Both Street Supremacy and AirSupremacy Ford Intake Manifolds get an update .
Pictured are some basic CAD pictures showing my new Race Intake Manifold to suit 9.2" & 9.5" decks .
Upgrades include . Straighter end runners , Better Line on sight , smaller plenum , substantially lighter casting . Multiple runner core sizes .
CAD still requires a few touch ups
Newold1 , ok are you meaning more of a longer and wider plenum, im not sure i have pictured in my mind correctly what you and Bill are getting at as far as how all the runners would be at the same length etc and enter the plenum in the same fashion due to the intake port angles on the Cleveland based heads im picturing one whole bank worth of runners being snaked rearward and the other bank snaked forward to get near the same at the plenum OR 4 runners from one bank being way forward of the other bank? 6.30am here ,, you're twisting my brain !Newold1 wrote: ↑Thu Jun 06, 2019 9:06 amI totally agree that modifying the top of this wonderful manifold would not be ideal as it is definitely configured for a single carb or throttle body.cjperformance wrote: ↑Wed Jun 05, 2019 7:24 pm Look at how each runner pulls from the traditional style open/single/square plenum. Its hard enough to control how each runner pulls from a fairly uniform shape plenum. When you make the plenum longer you now have put the 4 outer runners up at the ends of a plenum and the 4 inners are right in a big open space. This messes fuel distribution up even more. You can fix this by pulling the ends of the plenum out further , moving the 4 inner runners out a little 2 toward the front and 2 toward the rear and reduce the inner plenum area so the plenum is not too big, you then need to bring the runners up higher to clear engine components due to the longer 'moved out' plenum setup,,, ah now that sounds like a tunnel ram!
What I was referring to was that Scott had answered Bill with a "great idea" comment about setting up a tall spider like manifold like this where all four outer runners would be equaled up with the inner 4 runners and throttle to head port entries would all be the same angle, size and volume. Using two big 2 barrels like the pic I posted would allow the carb to be split to say that the air fuel distributions would be much more equal and balanced. No intake system except ITB system will even the pulses in a 90 degree V-8 so that is a given. It's somewhat obvious that when ultimate power in an N/A engine is desired in applications other than maybe drag racing that even fuel mixture distribution is needed that runner direction into symmetrical port V-8 heads it's the best. Prime example is your awesome Australian Super Cars. I am not a big fan of hanging onto carburetors for performance applications and I still believe sequential port injection is better for even fuel mixture distribution.
Cheers
I've tried lengthening the Plenum . Predictable! . Higher rpm power gains at the expense of lower and some mid range . It tested ok , But !! What I didn't like was the A/F's and egt data collected . Certain end runners / cylinders ran very lean both in data and plug reading .Newold1 wrote: ↑Thu Jun 06, 2019 9:06 amI totally agree that modifying the top of this wonderful manifold would not be ideal as it is definitely configured for a single carb or throttle body.cjperformance wrote: ↑Wed Jun 05, 2019 7:24 pm Look at how each runner pulls from the traditional style open/single/square plenum. Its hard enough to control how each runner pulls from a fairly uniform shape plenum. When you make the plenum longer you now have put the 4 outer runners up at the ends of a plenum and the 4 inners are right in a big open space. This messes fuel distribution up even more. You can fix this by pulling the ends of the plenum out further , moving the 4 inner runners out a little 2 toward the front and 2 toward the rear and reduce the inner plenum area so the plenum is not too big, you then need to bring the runners up higher to clear engine components due to the longer 'moved out' plenum setup,,, ah now that sounds like a tunnel ram!
Cheers
David,David Vizard wrote: ↑Thu Jun 06, 2019 11:34 amScott,Scott wrote: ↑Sat Jun 01, 2019 1:09 am Both Street Supremacy and AirSupremacy Ford Intake Manifolds get an update .
I am still working on my SBF book. When these intakes become available can I get a loner to test? Engine power range would be from about 650 to 800 hp.
Also could you PM me with a tel # so I can talk to you about this intake.
DV
Scott,Scott wrote: ↑Sun Jun 09, 2019 3:36 amDavid,David Vizard wrote: ↑Thu Jun 06, 2019 11:34 amScott,Scott wrote: ↑Sat Jun 01, 2019 1:09 am Both Street Supremacy and AirSupremacy Ford Intake Manifolds get an update .
DV
I sent you a PM
Was that peak power? Can you post a dyno sheet.Kenny M wrote: ↑Fri Jun 14, 2019 10:45 am I just completed a 9.5 deck 441 CI. NA. Engine, using Scotts Heads and his old Manifold. This power was made with a small low lash 268 .790 .730 lift camshaft and stock location 2V style exhaust ports. There is more power to be found in this engine. This was just a few baseline runs with a very long street header. Scott is a wonderful person, super passionate about engine development and builds some Killer stock looking heads.
Ken Maisano
