I was over a freind's house, he 's installing round case glasspack mufflers on his old Ford truck...I noticed the inner tube had many small louvers...He figured to install the mufflers so the open end of the louvers face away from the engine for better gas flow..??? I told him it's been said that typical glass packs are restrictive despite the fact the inner core is straight through and the same diameter as the exhaust pipe..
Yes, old school nonsense, get a real muffler, LOL... Any opinions of flow direction ?
Glasspak mufflers.. Yes
Re: Glasspak mufflers.. Yes
There cheap, and brassy sounding at full throttle with minor performance gain!
Any type of Turbo oval can type muffler will be a step up from those, and since he has a truck with way more free space then a car if he's hung up on using those atleast put them in after the tail pipes get over the rear end and the Exh flow is far less dense and hot at that point so a restrictive type muffler eats up less power.
It's a flathead V8 that on a good day may have 100 HP, He wants the "traditional" sound
Oh Gez! That's a far different story I though you where talkin like mid 60s ,then have at it with those glass packs!
mufflers are all about sound, I dont worry about performance either way
If it sounded bad but picked up 10hp which he wouldnt feel would he still do it?
I have a pair of those I use to drive to the exhaust shop. They sound awful. Maybe with pipes they could be better, but I wouldn't chance it.
From what I've herd, flow into open louvers = less hp and noise and vise versa for the other way. Perforated tube mufflers are much better!
If you run them with louvers pointed towards engine they are a bit quieter and a bit more restrictive. Pointed away is the opposite effect.
Best muffler is round or oval case with smooth perforated tube 3 inch diameter and high temp packing like the MagnaFlo.
