The issue is that people using aftermarket rocker systems at whatever lift figure they have, is mostly a different mid-lift number for every application.
Those people don't design their own rocker arms and are relegated to using what is already in the marketplace.
A rocker arm designed for .500" maximum valve lift will not be correct on both sides at .750" maximum valve lift so, it is required that you work with whatever you have to probably arrive at the best compromise.
