It depends on what compression you can get with both types of pistons, and what fuel.
With unlimited fuel, I would take 14:1 and domes, over 12:1 and flat tops.
If your fuel is limiting you to 11:1 with domes, I'd rather run 10.5:1 with flat tops.
Well, what's the max compression you can get with flat tops, and what's the max you can get with domes ?
I'm not familiar with Torco 112. Will it respond well with 14.8:1 ?
With Q16, I'd go 14.8:1 with domes.
