Honda rod Journal?
88bluestar
Honda rod Journal?
Post by 88bluestar » Sat Apr 13, 2019 8:22 pm
Have a set of 6.125” H beam Eagle Honda rods for a small block Chevy on and eagle 45 lbs crank.
Question being does anyone else make bearings aside from the Clevite Cb1780H? , std size.
ProPower engines
Re: Honda rod Journal?
Post by ProPower engines » Sat Apr 13, 2019 8:44 pm
I believe ACL and King both have tri-metal bearings. But in the coated race only version.
I would call king 1st as they will be less costly compared to the others.
Charliesauto
Post by Charliesauto » Sun Apr 14, 2019 1:31 am
Assuming you have 2.008" housing bore in your rods? Federal Mogul 8-7195CH would also work, I have used hundreds of those.
Krooser
Post by Krooser » Sun Apr 14, 2019 6:46 pm
I have heard that Honda has two different rod journal sizes...
I have a set of Pankl rods with a 1.979 + or - big end. Do these fit a 1.890 rod journal?
Anyone have a part # for a std. rod bearing? Never done this Honda deal before.
novafornow
Post by novafornow » Sun Apr 14, 2019 9:55 pm
Check with Callie’s about their Daido brand bearings. They have a lot of Honda sizes
Krooser
Post by Krooser » Sun Apr 14, 2019 11:41 pm
Found my answer... the rods I have are for the Honda 1.850 journal. Bought a set of bearing tonight. Thanks for the help guys.
88bluestar
Post by 88bluestar » Mon Apr 15, 2019 11:49 am
These are what I have, Need replacing? I have standard CB1780H bearings
Crank is very clean, no noticeable wear.
