New compression building
Wiseco has come up with this new product to build compression and comes in a can.Made for stock eliminator in heads up situations.
Re: New compression building
But this was posted on April 2nd.
Then it must be real! LOL
Paul
Sweet gotta getz me some of that......anyone know who sells cam n lifters in a can too ????
Add one of those 2 carb to single adapters and there's no end to the power potential. !!!! LOL
I cannot make more power with my $$$$ 1 big carb, So no way you can make power with 2 carbs And I have a dyno. Only I know.... Thus you must bring your money to me.
Imagine the biggest induction tract cluster F--K you can think of and it's similar to that.
Now there's a phrase that needs to be more common in usage.cluster F--K
A tunnel ram set up with 2 adapters on that would make a total of four 4bbl carbs...ultimate HP. That would put a 350 with vortec heads right up there with a 500cid Pro stock engine...plus get 23mpg.
It says "Use only high octane fuel!"
I think it should have said Diesel.
It's probably 20:1+ compression ratio there!
Yeah it was posted a day late!!
Don't buy that High priced stuff. Get it off TV on the Specials..
You know them Flex steel, buy one get one free...
Adger Smith
903 794 7223 shop
903 824 4924 cell
adgersperf@aol.com e-mail
903 794 7223 shop
903 824 4924 cell
Great. Now were going to get to listen to you go on about this every day, too, huh? Flowz and carb adapters. Your favorite things.
Smfh.
adapterZmakin chips wrote: ↑Wed Apr 03, 2019 5:11 amGreat. Now were going to get to listen to you go on about this every day, too, huh? Flowz and carb adapters. Your favorite things.
Smfh.
