Water in oil pan
bigfoot
Water in oil pan
Post by bigfoot » Fri Mar 29, 2019 9:19 pm
I drained the oil in my 347 and some water came out when l removed drain plug..l took the heads off and changed the head gaskets intake gasket and water pump gasket..l put it back together and ran the electric waterpump..still got a little bit of water in oil...one of the head s was repaired a few years after it smashed a valve.
.l never had the heads magnihluxed when l took them off the other week...l guess l should of ?
Steve.k
Re: Water in oil pan
Post by Steve.k » Fri Mar 29, 2019 9:27 pm
If not Intake manifold leak then likely head. You can have head pressure tested for leaks.
Baprace
Post by Baprace » Fri Mar 29, 2019 9:28 pm
If the water is clear then it is probably rain water.
Steve.k
Post by Steve.k » Fri Mar 29, 2019 9:33 pm
some heads have threaded plugs like these that can start to leak as they warm and expand.
bigfoot
Post by bigfoot » Fri Mar 29, 2019 10:12 pm
The heads are dart jr steel heads...1.94 intake valve...is there a dye l can put in the rad ?? Then.l can take it apart again to look for signs of it leaking
swampbuggy
Post by swampbuggy » Fri Mar 29, 2019 10:25 pm
Each and every time a cold engine is started, and as it builds heat it creates condensation/water inside the engine. "IF" the engine is NOT run long enough to get HOT enough to evaporate that moisture out you will have some moisture/water settle inside the engine most likely in the oil. I am not saying this is what is causing your issue, just saying this is a fact. Mark H. :)
4sfed
Post by 4sfed » Sun Mar 31, 2019 9:00 am
Try the Lisle block tester. It will tell you if any combustion products are leaking into the cooling system. Cheap and easy ... https://www.amazon.com/Lisle-75500-Com ... 552&psc=1
Belgian1979
Post by Belgian1979 » Sun Mar 31, 2019 4:20 pm
remove the thermostat housing and fill up the block with water untill just blow the edge of the thermostat housing. Then use the air adapter to put pressure in the cylinders. If a head gasket is damaged, you'll see air bubbles in the place where the thermostat normally is.
Baprace
Post by Baprace » Sat Apr 13, 2019 7:31 pm
bigfoot, what did you find on your oil & water issue ?
ja411
Post by ja411 » Sat Apr 13, 2019 9:31 pm
Look up tracer dye for coolant systems. Pour into radiator run your electric water pump to circulate. It's used with a black lamp for small leaks but is bright enough to see without. It's worth it's weight in gold have been using for 20+ years. They make it for A/C, cooling systems and 4 in 1 for oil and hydraulic systems.
Joe
