Solid block cooling
Solid block cooling
You guys that run 1/8 mile with solid block and coolant through heads. Will they stay cool enough on return road? With rad and fan setup all alloy on gas. He has a grouted iron within 1" of deck now with no issues. Wants to switch to alloy. Hes wanting to avoid tow vehicle. Ive only worked with wet block. Thanks Steve
Re: Solid block cooling
If it's on alcohol, you MIGHT get away with it, but I wouldn't chance it.....better to tow....On gas, no...too much heat buildup...not worth the effort
Mark Goulette
Authorized Amsoil Retailer
- Dave Koehler
If he can pit near the top end he Might get away with it.
Might want to consider alky.
- Dave Koehler
