Ported Chevy 083 heads, the tpi project
Curtis Mc
Re: Ported Chevy 083 heads, the tpi project
Post by Curtis Mc » Mon Mar 18, 2019 4:37 pm
Carnut1 wrote:
Mon Mar 18, 2019 3:45 pm
very interesting results
Meaning? You thought they would be further apart, closer, more flow, less flow?
Great effort, kudos on finding out what's what and close to the casting limits in some cases.
Carnut1
Post by Carnut1 » Mon Mar 18, 2019 4:42 pm
Yes, I was expecting much more from the slp modified runners. Now that may just mean the obstruction is somewhere else. I need to take some more airspeed #s. Thanks, Charlie
cuisinartvette
Post by cuisinartvette » Mon Mar 18, 2019 8:07 pm
Wonder if sheer runner length and csa limits hold you back from more?
The joys of trying to make a fat lady dance haha.
randy331
Post by randy331 » Tue Mar 19, 2019 10:24 am
Carnut1 wrote:
Sun Mar 17, 2019 8:10 pm
After a bunch of work with no real gains I decided to look closely at this chamber.
The chamber side of the valve is much more likely to lead you down the wrong path, than the port side of the valve.
Carnut1
Post by Carnut1 » Tue Mar 19, 2019 12:11 pm
I took a long look at that as well. I know the system flows more with a bigger port but is that wise? Having fast air in the runners and a lazy port may not be a great combo. What I think would work well is have each section close to flow and csa so the airspeed is similar. I haven't done any long runner applications so I don't know. Thanks, Charlie
LoganD
Post by LoganD » Tue Mar 19, 2019 12:26 pm
I've done a lot of long runner development, what you are saying is right. You don't want large airspeed changes in a given runner/port section. Your fastest air should ALWAYS be in the head, at least from an average velocity standpoint. This will produce a responsive engine with good transition response between middling load to high load. This isn't always the easiest thing to see in a static flow bench test.
randy331
Post by randy331 » Tue Mar 19, 2019 12:28 pm
Sorry, meant to say the flow bench will lead you down the wrong path on the chamber side, much easier than the port side.
Chasing flowz on the chamber side is likely to take you backwards.
Carnut1
Post by Carnut1 » Tue Mar 19, 2019 12:40 pm
Thank you!
Carnut1
Post by Carnut1 » Tue Mar 19, 2019 12:45 pm
So Randy, I will admit I did not expect such a large flow gain by some chamber deshrouding. Do you think the shrouded chamber had the ability to make more power with less flow? If you do what do you think some of the reasons that would happen? Thanks, Charlie
LoganD
Post by LoganD » Tue Mar 19, 2019 12:55 pm
That's easy, a shrouded valve will cause more charge motion, generally in the form of tumble. This will help BSFC and knock resistance. Most modern tumble port 4-valve heads deliberately shroud the area of the intake valve near the cylinder wall to cause a low pressure condition that forces tumble.
slo-svt
Post by slo-svt » Tue Mar 19, 2019 1:12 pm
Logan what does the D stand for? David?
"I believe in the scientific method and one should have a healthy skepticism of things in general. From a scientific standpoint, you always look at thing probabilistically and not definitively."
Elon Musk
Carnut1
Post by Carnut1 » Tue Mar 19, 2019 1:31 pm
I have seen that, now often on ST pros will state they will rather have higher flow than swirl or tumble. As far as a wedge chamber from what I have tested (flowbench with swirl meter) they actually have too much swirl and a step back would be better. Thanks, Charlie
F-BIRD'88
Post by F-BIRD'88 » Tue Mar 19, 2019 2:07 pm
The amount of swirl/tumble produced at the chamber shrouded near the in valve is relative to engine rpm.
A engine running at part throttle at 1600 rpm in OD needs a lot more induced tumble/ swirl than if running at 5000 rpm ++++. What works and gains at low rpm (the stock motor) can be way too much effect at high rpm on a racey engine. It is relative to the job the engine is intended for. And its rpm range.
F-BIRD'88
Post by F-BIRD'88 » Tue Mar 19, 2019 2:11 pm
You would want to dyno test compare the result of your chamber mods to see if the increased flow gets you increased dyno power or torque.
Interesting budget hot rodded sbc head on a capable hot street/strip 355 or 383 (sans the tpi system.)
But the modded tpi should make lots of mid torque.
These tpi heads in Carnut modded form are a great alternative to vortecs or old 60's camelbacks for street strip on a budget and the oem look.
The 081 305 TPI motor cast head is another potential candidate. The smaller chamber "081" allows for even more creative die grinder carving. Lots of both these around as many were swapped out for aftermarket heads in the TPI motor power search frenze of the 80's and 90's.
The twinned center exhaust egr passages need to be blocked to stop center ex port cross talk and cooler running at WOT with headers.
naukkis79
Post by naukkis79 » Tue Mar 19, 2019 2:18 pm
If done like Cosworth 60's patent tumble is made with port bias - port is at different angle than valve and at high lifts flow detach from SSR and makes SSR side of valve low pressure area, which with upper valve part flow directed downward with chamber creates tumbling motion in cylinder. More valve lift than what is needed for max port flow increases tumble even more so its usual to lift valves much more than what is needed for max flow. Modern eco-heads have skijump in port floor to detach flow from SSR without high valve lifts.
There is no low pressure area where chamber shrouds valve, only restricted flow.
