Ported Chevy 083 heads, the tpi project
Carnut1
Post by Carnut1 » Sun Mar 03, 2019 1:10 pm
Project for a friend, 87 tpi engine. 083 cylinder heads pictured washed with oil from honing the k line guides.
Carnut1
Re: Ported Chevy 083 heads, the tpi project
Post by Carnut1 » Sun Mar 03, 2019 1:15 pm
083 cut for 2.02" /1.6" valves. The stock seats and guides were hammered.
Carnut1
Post by Carnut1 » Sun Mar 03, 2019 1:20 pm
Rough out
Carnut1
Post by Carnut1 » Sun Mar 03, 2019 1:24 pm
1st design for flow tests.
Carnut1
Post by Carnut1 » Sun Mar 03, 2019 1:33 pm
1st flow test. These are very similar to what I did in the 90's for the old work truck's 355 that I still drive. Not spectacular but close to Vortec bowtie flows.
Carnut1
Post by Carnut1 » Sun Mar 03, 2019 1:44 pm
With 1st cut on head I started flowing parts of the tpi manifold to determine where the restrictions are. Stock tpi base knocked flow @.5" to 208 cfm, stock tpi tubes added 193 cfm, aftermarket siamese runners 183 cfm all with clay radius.
Carnut1
Post by Carnut1 » Sun Mar 03, 2019 1:58 pm
Ported base brought flow @.5" up to 223 cfm with clay radius.
Carnut1
Post by Carnut1 » Sun Mar 03, 2019 2:10 pm
Ported stock tpi runners bring flow @.5" to 200.5 cfm, ported aftermarket runners 190 cfm. The aftermarket runners are full of restrictive bulges. You will need a good sonic to get a decent shape. Stock tpi runners has very little metal to remove.
Carnut1
Post by Carnut1 » Sun Mar 03, 2019 2:16 pm
After and before tpi plenum. This needs lots of work for the aftermarket throttle body this project will have.
PRH
Post by PRH » Sun Mar 03, 2019 2:18 pm
What did the stock head flow?
Stock head with stock base?
Stock head with stock base and stock tubes?
The work looks good.
Carnut1
Post by Carnut1 » Sun Mar 03, 2019 2:26 pm
After and before aftermarket throttle body.
Carnut1
Post by Carnut1 » Sun Mar 03, 2019 2:31 pm
I knew it would all get some work so I wasted no time flowing stock heads. I doubt they flow much above 200 cfm which seems a bit more than the stock system will flow. Thanks, Charlie
Carnut1
Post by Carnut1 » Sun Mar 03, 2019 3:27 pm
083 ported head 2nd port design, ported stock base, ported aftermarket siamese runners, ported stock plenum and ported aftermarket throttle body on bench. @ .5" lift 195.2 cfm. Pathetic.
Ported stock runners on same setup @ .5" lift 199.2 cfm
This was after quite a bit of work to aftermarket runners.Thanks, Charlie
PRH
Post by PRH » Sun Mar 03, 2019 4:01 pm
Do you have a decent single plane and carb you could try on it?
RevTheory
Post by RevTheory » Sun Mar 03, 2019 4:16 pm
Wow, that TPI is a real buzzkill.
